Page 4 of 12 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 167
Thread: 2jz into hilux
  1. #46
    wa
    Default Re: hilux conversion
    2jz aristo front cut ordered yesterday be prepared for a lot of questions
  2. #47
    wa
    first question
    how do i tell what year the front cut i have is
    i have to find out for the modification form to send to the dpi
    Also what is the oil pump modification i hear on the 2jzgte
    can anyone point me in the right direction i have searched but found nothing yet
  3. #48
    Default Re: 2jz into hilux
    look at the ID plate.
  4. #49
    wa
    it doesnt have a date on it i dont think it only has the one with the vin and model numbers,paint code and axle
    i couldnt see the year on this but i will have another look tomorrow
  5. #50
    turbo-a Grease Monkey
    queensland
    i stuck a 7mgte into a hilux 4runner 4wd, best fun i ever had, also the most expensive.Being 4wd with large tyres i broke every diff and gearbox i put behind it.2wd there are are alot more options with gearbox and diff.Id use a 1jz if i ever did it again due to the fact they have less torque and wont put as much stress on the driveline.All the best in your swap.....
    Turbo-A lives here!
  6. #51
  7. #52
    wa
    thanks mate im using the 2j auto and already have my diff sorted with a 3.9 lsd
    its only 2wd so hopefully i will break traction before breaking diffs
  8. #53
    1uz 4wd Hilux Grease Monkey Dust's Avatar
    Quote Originally Posted by ecotechilux
    http://framno.org/lite/
    Try that.
  9. #54
    Dreamer Backyard Mechanic millsi's Avatar
    if its like the 1uz the easiest way to tell is by looking what year is stamped onto the ignition leads (assuming they arent hi po replacements)
  10. #55
    Yeah that's right, i'm a Grease Monkey texasflysuperstar's Avatar
    Jan 2007
    Gold Coast
    i'll be watching this thread for sure.
    damn it, it sounds like the 2j auto will never mate up to my 4wd drive gbox in my Prado. this is one engine conversion that i was seriously looking into. oh well it looks like i'll just have to turbo the 3rz thats already in there seeing as lance and beRad have had great sucess with it.
    good luck with the build up dude.
    Patrick
    TA 22 - Top Coupe and Best Bodywork
    1994 Fours and Rotary Nationals
    Built by Alex Sumner
  11. #56
    wa
    it seems i have a 11/91
    dont know wether thats a good thing
    the motor seems in good nick though
  12. #57
    Where did you buy it, how much (please) and what exactly did you get for the money.
    Peter
  13. #58
    wa
    pm sent peter
  14. #59
    wa
    oh no
    just removed the rocker covers to do the gaskets and the motor has a fair bit of sludge around the cams
    i guess i may as well rip off the head while im half way there
    may as well do the valve guides and stem seals too
    i knew i should have left the rocker covers leaking
    Does anyone know how much to expect for one of those mv automatics shift kits
    may as well put one of them in while im here
  15. #60
    pm sent peter
    Cheers for that. I was just wondering what a spare 2JZ-GTE would cost.
    Peter
  1. late 97 on hilux 3rz turbo conversion walk through
    Last Post: 07-01-2011, 07:10 AM
  2. Rn110 hilux 1GGZE conversion
    By Bullfrog in forum Engine & Driveline Conversions
    Last Post: 15-02-2009, 08:17 PM
  3. 1GGTE to Hilux conversion help
    By nedm in forum Tech and Conversions
    Last Post: 12-10-2007, 03:39 PM
  4. Flywheel for 1G-GZE Conversion into Hilux
    By infotechplus in forum Tech and Conversions
    Last Post: 16-11-2006, 05:41 AM
  5. YN57 hilux power steer conversion - how to?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 13-11-2006, 11:15 AM
