geez, got questions??Originally Posted by bomber
1. do you have the disc brakes? these cars have mac struts with tiny springs, because most of the weigth is taken by the transverse leave spring . no swaybar, but K-mac make one that kind of vaguely fits.. maybe try whiteline or other...
they also have A-arm, so there is no radius rod... this will probably need to change for serious braking.
2. with some choppy (1 new hole in chassis rail each side for cross-member, spacing is different) and addition of radius rod mounts at front, you can adaptt the KE20 front end.
KE10 is skinniest of all rollas, so it's a bit tough.
3. KE20 have the same 200mm brakes. the KE30/55/70 brakes and calipers fit (218mm) but are not a huge improvement. with KE70, the SEA version (old bolt pattern of caliper mount to strut.. ie the square pattern) fits, but normal KE70 does not. KE30 and 55 are bolt on if you change disc, caliper and bracket... use KE20 hub if you don't have discs now.
4. minimum mods? not much. for serious braking ytou would want to get stronger stb axles/bearings anyway...
some say there are datto/nissan struts that fit easily into KE20, so if you went with the KE20 normal front end, change to the datto struts (R30? R31?) and then do the normal datto upgrades.. not a bad option.
5, you could, but it depends how much braking you will do.. the A-arm might not be the best for toe-in changes during braking,,, the radius rod style front end will be better.
shcoks in KE10 are 1" longer than KE20/30, so they can be made to fit with a spacer or strut shortening..
also KE10 has too much droop and not enough bump standard... so you need to add more bump anyway.
6. S13 struts and 280mm 300ZX discs with 4pots? rear, depends on diff.. no reason not to have big discs...
7, with such a light car, you may not need boosted.. especially if you run the much larger brakes. fitting a booster might actualyl make the brakes too touchy. there is not much space in engine bay... you could roue it into cabin, but not much space there either
8. KE10 is skinny. adding a bit of track would be good. S, T, F and G diffs are common, in ascending order of size/weight/strength. you mght get away with an S or T series, if you are staying NA. an F with atorsen centre would be nice. people HAVE fitted G series under there, so it is possible if you want a big heavy rear that won't ever break.
you could also look at BW diffs, but being banjo style, and LSD's not being so great.. might not be best option. F with trutrac?
9. yes, kinda. you can do the usual tricks with leaves,and a panhard/watts would be great i made new packs with a second big leaf, but when lowered, the spring geometry is not great... you don't really want blocks in there...
10. sure it can be done... a pain, but would be the best option.. there are plenty of pre-made bits for various cars that could be used to make the top links int he floor... would need to reinforce well since they are not so beefy in that area.. might be able to use the leaf mount for one body mount tho.
need to strengthen the shock towers to take force of springs too... good time to go coilover in rear for space saving. (for exhaust and the like.. and take out wheel well and fit tank there for lower weight)
i would like to try this, but keeping a KE70 width, which increases track by about 100mm, so check with engineer about that legality, or use bigger offset rims to reduce it a bit...
11. you can get koni reds for the front, and tokicos, btu dunno abotu adjustable.. it all depends on what sturts you run.. i figure you will change them, so somethinglike S13 would easily have adjustables rear will be custom too, since the KE1x shocks mount different to others...
12. i think it is 11/16, single circuit. if keeping standard corolla size brakes (up to KE70) you can swap for Galant (GA-GD) which are dual circuit and either 11/16 or 3/4... but with 4 pots or similar, you will need more fluid, but unboosted should have agood firm feel but not be too hard. saves space too..
13. no, they are solid. BUT if you kept the KE10 front end, the KE10 pitman arm bolts to the KE20 collapsible column, and you need to fab mounts for the collapsible bit in the cabin, but otherwise the KE20 column is the way to go for simple collapsible.
you could go to a KE70 column if you want to move to a rack and pinion front end... or AE86 is the same but with height adjust?
you will need to have engine engineered anyway.
even if you took brakes completely off another car, the bias will be wrong cos the car is very light, so don't be afraid to put different brakes on.... if you do keep from same car (or same dimensions, esp piston and disc size) then it might make the proprtioning easier.. maybe go a little smaller on the rear to make sure you have frotn bias....
in short...
first ask if you can widen track. then choose either KE20 or KE70 front end (KE70 needs some mods to cross-member to have new holes to bolt in). both need radius rod mounts. you migth wanna strengthen the strut towers.
struts... choose the brakes and then make struts fit S13/14 or datto R31??? are easy to swap brakes onto. you could keep it toyota and do pug/hilux, but that would be heavy. S13/14 (with ball joint issues maybe?) and 300ZX/R32 discs and calipers would be nice
diff, F with trutrack would be good if you plan power/abuse down the track, but T series is also ok for light car (with clutch pack LSD, easily available too).
4 link with watts would be perfect depends if gingerbeer likes that idea... i like it.
have fun
ps, if you need a plastic model to look at body styling changes, i have a couple
