Page 1 of 12 12311 ... LastLast
Results 1 to 15 of 178
Thread: Hilux front brakes
    is a semi-motivated Domestic Engineer 1JZ~lux's Avatar
    Default Hilux front brakes
    G'day, I'm about to start my brake upgrades but I'm not sure how the 4WD hilux brakes will fit as I've never seen them. If anyone can post some info or pics it would be much appreciated.
    Default Re: Hilux front brakes
    Toyota Landcruiser 4 piston caliper
    or these
    cheers,
    Peter
    Another alternative (with some mod work required) is Nissan R32 front calipers and rotors. You need to get the centres machined to make them slightly larger to fit the Hilux hub, and a 20mm spacer to realign the caliper over the disc but I'm told they bolt up OK otherwise. Not a lot of work for excellent brake package.
    I think the Landcruiser setup is much heavier but can't confirm. I'm currently rebuilding the R32 setup for my RN85.
    and
    Dreamer Backyard Mechanic millsi's Avatar
    i will be going for a hopper stoppers 330mm kit in mine (rn90)
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    infotechplus: do you have any more info on those brakes? Do they bolt onto the stock Hilux hub? What rotors do i need to use?
    Cool Re: Hilux front brakes
    Quote Originally Posted by -==L=a=N=c=E==-
    The Landcruiser calipers bolt holes are approx. 90mm but the Hilux (eg. my RN85) are 100mm so they would require some work eg. a mounting bracket.
    Peter
    Landcruiser Calipers
    76-90 Models FJ40 FJ55 FJ60 FJ62
    91-92 FJ80
    93-97 FzJ80
    Peter
    Hi Peter, you don't happen to know the bolt spacing on those last two cruiser calipers you have pictured there? The FJ80 and FZJ80 (I would assume the caliper bolt spacing is the same on those two calipers pictured??)
    89mm spacing.
    Interesting, the way those pics look it appears the bolt spacing is greater than the spacing on the caliper in the first pic
    Yeah, i know at least the up to FJ62 calipers and the LN130 calipers are 89mm
    Rosewood
    Quote Originally Posted by infotechplus
    Peter
    Thats handy to know, hopefully my RZN149 hubs have the same 100mm spacing. Would mean that the Z32/R32 calipers should bolt up, with some appropriate discs for brake upgrade.
    Yeah, R32 calipers (which are the same casting as Z32) are 100mm spacing.
    Anyone know of any macpherson type strut tubes with the 100mm spacing? Or know if the Hilux caliper brackets are a bolt-on type, or if they are welded/cast to the hub/spindle.
    Yes.
    The mods are:
    Enlarge the centre to allow the R32 rotors to slip over the Hilux axle stubs; and,
    Create a 20mm spacer to shift the caliper centre over the rotor (bolt pattern on the caliper is the same as Hilux)
    Peter
    nice work!
    +rep!
    Rosewood
    i'd rep you again, but i've already repped you infotechplus. Great info!
    What size wheel would you need? does the stock 14" still slip over or not?
    What of brake lines as well?
    By The Witzl in forum FAQ
  2. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 10:54 AM
  3. Replies: 4
    Last Post: 08-09-2005, 01:17 PM
