did those mechanics finish high school?
they don't care because it is not their motor, and they don't have to pay if it breaks...
perhaps
when i use plastigauge i do every journal and when other mechanics walk past they say just do one or two, if im building a stocko motor ill just do half but if im building a performance engine i do every single one because i work off the fact that anything can happen and id like to be able to sleep at night.
what do you people do just curious, ill always do everyone i cant rest unless i know.
perhaps
wow your fast
yeh your probably correct, dam people that can sleep and dont worry, actuly how cool would it be
after just rebuilding my motor
i did every one.
i like to do things right. as stu said maybe some mechanics have more trust in their machinists?
trust no one
bearings have been known to be mis packaged IE +20 marked as standard.. Plastiguage is cheap... you could build my motors anytime...
Might as well jack the thread since its on the same topic I assume you should oil the journals and bearings beforehand or measure when totally clean? Also what position of the crank is best to measure at?
i always do mine dry.
and umm, you lay it along the width of the journal, and it doesnt matter what position the crank is in, its meant to be round...
I just wondered if different positions would show inconsistencies in the crank journal diameter not being perfectly round. But then I guess you have another problem then.
yes u would, and im not sure if plastigauge would be accurate enough for something like that?
may be worthwhile, but it depends how much time you have on your hands...
only takes 5 mins to do it properly! i dont know why anyone wouldnt!
do your measuring first then, when everything is within spec and OK - then oil your bearings ect and tighten things up.
do not oil bearings ect up then use plastigauge.
I just plastigauge every journal in my 7m 2 nights a go....its not hard....lazy mechanics..
