Results 1 to 7 of 7
Thread: adding Power Steering
    Junior Member Grease Monkey DBoy's Avatar
    Aug 2006
    Default adding Power Steering
    Is adding power steering to a car that doesnt have it possible? its a rt142 corona and mine doesnt have power steering. it doesnt really bother me just wondering if it would ever be worth the effort. some of the coronas do have it so the parts are out there for it.
    Default Re: adding Power Steering
    Yes it's quite possible if you get all the required parts. This generally means the complete steering rack, hydraulic pump including brackets/pulleys/belt, and of course the hydraulic hoses. Whether or not the cost/effort involved is "worth it" is entirely up to you.
    Aug 2006
    swapping the steering rack sounds like a lot of work
    Nah, thats probably the easiest part.
    You may have to get the proper steering arms aswell.
    ive put complete ra60 crossmember and power steer into my 77 celica.
    lot easier in your case as the pwr str rack should just bolt in place of your std rack.
    bolt on the power steer pump and brackets. connect a few hose clamps and your done.
    Black Betty >HERE!<
    (\__/)
    User Conversion King
    NWA
    RA60, RA65 are also a source of these parts
    same engine (ra65 only) and 90% chance its the same xmember (check with your tape measure)
    you may also have to change the main pulley on the front of the crank if it doesnt have the required grooves.
    pressing out the mongrel ball joints is probly the hardest job in it
    hello
    I wouldn't bother.. could play with the castor if you find the steering is too heavy. Or just be a man.
  1. 1992 Merc - Where is my power steering reservoir?????
    Last Post: 03-11-2006, 04:32 PM
  2. accidently toped up power steering with brake fluid?
    By gerald1 in forum Tech and Conversions
    Last Post: 12-08-2006, 05:52 PM
  3. AE82 Manual ---> Power steering conversion ease
    By hemi twofifteen turbo in forum Tech and Conversions
    Last Post: 24-05-2006, 05:09 PM
  4. Power Steering (n00b question)
    By ZZE92 in forum Tech and Conversions
    Last Post: 28-12-2005, 11:52 PM
