Page 2 of 17 FirstFirst 123412 ... LastLast
Results 16 to 30 of 251
Thread: Toymods Dyno Day 14 - Sunday, January 21st
    SO00RA Domestic Engineer 4agerolla's Avatar
    Default Re: Toymods Dyno Day 14 - Sunday, January 21st
    Ill be there in one of the soarers!
    Cant' wait!
    - Silver 2012 Lexus ISF - 2UR-GSE 5 litre V8 goodness
    - Black JZZ30 Soarer - 1JZ-GTE VVTi + factory R154 manual
    - Blue KE17 Sprinter- 3k + K40 manual
    - White MS55 Crown - 2M + 4 speed column shift manual
    - Blue MS51 Crown Hard Top - Angry 4M-B + W50 manual
    No median strip excursions this time.
    I will be there.
    Quote Originally Posted by BlackSupra
    I will be there.
    cut me deep lol
    I will be there.
    And here i was thinking you had been lost into the haze of the collective toymods memory.
    I too will be there, however my car's attendance remains uncertain.
    Toymods Club Member
    Is not a good Backyard Mechanic GtiRboy's Avatar
    N.S.W
    i might possibly be there, will be interesting to see how much stock power my stivo has
    might also bring along INCHRG, its a short wheel base toyota 4WD with a turbo diesel engine conversion, just maybe to see what she is putting out..lol
    Mmmmmmmm 2ZZGE
    Yellow Belly Black Snake Backyard Mechanic Sprinter-Saurus's Avatar
    New South Wales
    Quote Originally Posted by GtiRboy
    You got any piccies of said beast dude ?!
    1984 MA61 Supra - 7mge.
    Toyota Hilux 2.8L TD 4x4.
    N.S.W
    i will bring some piccies soon..its nothing special, no lift kit or anything, just the stock forbie with the turbo diesel engine hehe, been up to qld and down to melb and stuff in it (pilot driving - the little vehicle with flashing lights following a wide load on a truck )
    Mmmmmmmm 2ZZGE
    Junior Member Backyard Mechanic v8soarer's Avatar
    Jun 2006
    I should be there too. I'll be getting my car retuned after fitting lightly ported heads and 265 degree cams the week before so hopefully I don't hit any snags.
    My TT 6 speed manual V8 Soarer (sold)
    Wakefield: 1:06.7
    Phillip Island: 1:51.9
    how bout dry ice coolers?.....
    are there any real restrictions to go by?
    Mate at the moment there really are very few restrictions. This is mostly because we don't want to discourage people from trying things out. As long as it's based on a Toyota engine and the car is safe to run then it should be fine. The only real restrictions are that it can't drip anything on the dyno but that's more because it's a pain in the arse cleaning up and makes it more dangerous for falling over.
    In future if we find that we grow to the extent that we end up with specialist dyno queens coming along and dominating then we'll need to look at running a demonstration class much like they do at the summer nats.
    Quote Originally Posted by Joshstix
    No danger of that with dry ice, it skips the liquid state, straight from solid to gas.
    Toymods Club Member
    ahhh, but water tends to condense of the cold metal around it
    Damn you Well done, i stand most humbly corrected.
    Toymods Club Member
    bahaha -GT- = pwnd
    i should be there, good fun day, hopefully my power will go up again, not down further...hopefully my manifold won't have loose bolts to the turbo this time
    also considering a couple of small changes if i get around to them, tho i have my doubts lol
    27.90s @ Esses Hillclimb
    Quote Originally Posted by Roundy
    My 3S did that recently. Although lose is a fairly understated term for it. One of the nuts was at least 1cm up the stud from the flange. But that was the good one, one of the other studs had actually managed to come out of the manifold. No wonder boost response was getting slightly tardy
    lol cone lock nuts ftw!
    before i used the cone lock nuts i lost all the nuts off the manifold to turbo on the way home one day fooking loud
    however one of the bolts i use needs to be short cause otherwise i couldn't get it into the flange cause the manifold is in the way, which means i can't use a cone lock nut on it
    how did you work it with studs, seems like a good option for me
  1. Toymods Dyno Day 13 - Sunday, July 2nd
    Last Post: 21-07-2006, 12:32 PM
  2. Dyno day 21st January
    By chris davey in forum Queensland Events
    Last Post: 03-03-2006, 07:01 AM
  3. Dyno Day 12.5 - Saturday 21st Jan. - Show of hands?????
    Last Post: 28-01-2006, 12:38 PM
  4. Dyno Day 12 - Sunday January 15th 2006
    Last Post: 25-01-2006, 10:46 PM
  5. Replies: 6
    Last Post: 10-01-2006, 01:11 PM
