Page 1 of 5 123 ... LastLast
Results 1 to 15 of 71
Thread: calling all you 5m-e speciallists! work this one out
    JZA61
    Guest
    Default calling all you 5m-e speciallists! work this one out
    The deal is i have to keep my 5m-e running until i put the 1j in. its developing a harmonic vibration sound that comes when revved to about 3 grand, engine will do it free revving too so its not the tail shaft. any help would b greatly apreciated thanks. jono
    Default Re: calling all you 5m-e speciallists! work this one out
    exhaust rubbing against the body somewhere?
    JZA61
    Guest
    dont think so, ill chek. edit: no exhaust is fine.
    Blame the air pump, it's always the air pump
    crank pulley or something attached to it.
    loose intake piping
    Toymods Club Member #302 Backyard Mechanic hi-ace's Avatar
    Try to narrow this down a bit for us.
    1/ is it the engine vibrating? place your hand on it when you bring the revs up.
    2/ is it a vibration sound only? ie: something attached to the engine thats loose.
    Answers to these question might help zero in on the problem.
    If it feels good "DO IT" Unless it harms others.(or upsets the RTA)
    Enjoy what you have To Day,cause you can't take it with you.
    My old Hi-Ace
    JZA61
    Guest
    ok havnt done the hand on engine thing yet but i do have this... i can feel it vibrate under my seat when free revving, its a harmonic vibration so it goes "vvvrrrrr....vvvvrrrrr....vvrrrrrr...vvvrrrrrr " not just "vrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr". hand it seems to get faster when revved higher, itake pipes are all on fine.
    and its not a rattle like sumthing is loose, it feels like its deep in the engine or gear box.
    Keep it under 3 grand?
    Friends
    Junior Member Backyard Mechanic benjamin's Avatar
    fuxored driveshaft uni???
    JZA61
    Guest
    drive shaft doesnt spin on idle, its there under 3 grand but gets bad at 3 grand
    Not being a professional mechanic. So please don't quote me, just throwing out ideas.
    Could be "crankshalf" related ie: main or big-end bearing.
    If it's manual, free revving is this done with the clutch in or out?
    If it's in then your gearbox is stationary.
    If it's out then the input shaft will be spinning with the engine. Therefore could be gearbox related.
    My old Hi-Ace
    I had the exact same thing happen when I bent the pressure plate in my Supra, knocking it slightly out of balance. If there's nothing obvious happening externally this is where I'd be looking.
    This is assuming it's manual of course, you didn't specify.
    PS does this belong in the conversions section?
    no i dont think so norbie but you get that on the big jobs.
    me thinks there's a pulley problem.. can't say for sure what's on the belts in front but it could be alternator, aircon, tensioner bearing etc etc that can cause this ..
    JZA61
    Guest
    its mkIIsupracar.
  1. Article: Torque / Work / Power
    Last Post: 02-06-2006, 01:03 PM
