Results 1 to 15 of 16
Thread: Aluminium + Oxy Welding, Need some help.
    Default Aluminium + Oxy Welding, Need some help.
    Hey guys need to get some help from someone with a good amount of experience welding aluminium with an oxy. I'm having some problems welding piping onto a cast aluminium piece and could do with some advice.
    Or even if there is someone in melb that could come around and help me that would be better! I can give you some soughta payment for your help.
    Sorry if this is the wrong section.
    Malicious
    Junior Member Carport Converter JBs's Avatar
    Default Re: Aluminium + Oxy Welding, Need some help.
    I didn't know you could actually do proper aluminium welding with oxy, wouldn't the oxy acetylene put too much crap into the weld?? What I do know for sure, aluminium is usually welded with TIG using straight argon as the shielding gas. You can also do it with MIG using either argon, or some form of alushield depending on the thickness. But be careful whichever way you do weld it because aluminium is very picky with oxidisation getting into the weld and screwing it up.
    Taken completely out of context:
    Quote Originally Posted by ROTFL-ACT
    JB's quite funny
    Yeah worked out the oxidisation shit today. Just wasted the whole FKN day basicaly destroy some decent aluminium.
    Yeah you can definatly weld aluminium with an oxy, just proving to be more of a bitch today then I thought. I've had a good success with welding lips on my FMIC piping but when I went to join a piece of piping to the cast alminium it all went to shit.
    Malicious
    Fair enough mate good luck.
    JB's quite funny
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Quote Originally Posted by ReQuieM
    I do aircraft work, the only way to weld AL is to use MIG if you dont want to damage it 2c.
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    what? Automotive Encyclopaedia EVOSTi's Avatar
    just take it to a welder, prob cost you <$20 and that way you'll have a good looking weld and not damage any more alloy.
    Junior Member Domestic Engineer Alex's Avatar
    Aug 2006
    vic
    You can weld aluminium with oxy, i've done it a few times with 0.8mm sheet, it's a pain is the arse, thicker would be easier, and it has to be extremly clean.
    I've taken an inlet manifold to a guy who builds race engines to get a few mods done that required welding and he charged peanuts and did an exellent job.
    There are a couple of tricks to it. I'm assuming you have the right flux?
    The big problem with aluminium is trying to get the heat right. One trick is to run a low oxygen flame over the work to get a layer of soot on it, once the soot burns off you're at around the right temperature.
    Hold the flame a lot more horizontal than you do for steel or you won't be able to get the weld to travel.
    Don't try to run a continous bead for too long, I've found that welding for a while then pulling back to let the material cool, then starting again give the best results.
    Once you've got it mastered, grab a TIG and you'll never look back
    Jun 2006
    sa
    it may be that you are trying to weld to cast. Cast ali has a tendancy to be slightly porosity and can trap contaminats and oxide build ups, I have had issues welding cast with tig and mig, the best thing is to file a layer off cast, don't use an iron grinding wheel as this adds impurities to parent metal.
    ou may try preheating cast also as may burn out impurities and also allows even heat distribution to avoid cracking. Post heat is a good idea to reduce cracking.
    Good luck
    Yeah - I can remember welding a 4AG water pump, the impurities in that were amazing...
    Yeah right flux and rod. Like I said I've welded beads onto my FMIC piping (Aluminium) with good results. Not pretty but it all gets filed down anyway. Heres my procedure:
    Cut, test fit etc.
    Stainless steel wire brush the area being welded.
    Wipe down with acetone.
    smear on flux paste with wooden chopstick, I've been putting a decent 'toast spread' amount, is that too much maybe?
    Heat by waving the torch over both pieces. I generaly keep doing this untill most of the flux 'melts' away.
    Concentrate flame on the two edges, when they start to look to soften I add the filler rod.
    I've quite a few really good runs of bead doing this but at the same time I worry that they're not binding right, so I go over them again. I all so noticed that I dont seam to be getting the weld to penetrait right the way through. I can still see a clean edge on the inside of the piping. I've had the pipes lines up in vices horizontaly, and I notice that most of the time that when it starts to 'pool' it also sags so I'm tring to ad filler as soon as the pieces soften. Is this too early? should I be getting some steel piping or something to re-enforce and heat sink the aluminium as I weld? Or even stand them up verticaly and attempt to get a larger pool?
    Malicious
    Victoria, Mt Macedon
    Welding to cast alloy parts is a pain. I've always used TIG. Sometimes it all goes nicely, other times I can work for hours to get a good bead on the same piece.
    Taking it to a pro is suprisingly cheap and can save plenty of swearing.
    Hen
    Yeah after the amount of swearing I did yesterday I think thats gonna be my next action.
    Who would you recommend? I'm in the southern subs so closer is always better I guess!
    Also, Would it be best that I do alot of the resizing, cutting and prep before taking it there? or just rock up with the two bits, markings where to join and ask can you whack these together and let him prep it the way he needs to?
    Malicious
    Yes, do all the setup and marking you can. Make it foolproof. I've had stuff welded wrongly before even though it was clearly marked.
    Unsure of anyone down south. Try looking in the phone book or going for a wander around your local industrial area. If people aren't busy they're usually up for a chat and should be able to put you onto someone nearby.
    Montrose
    You live anywhere near Dandenong? The guy at Race Radiators has always done some pretty good things as far as I'm concerned. He also seems to be able to make good welds with bad metal (cast etc.)
