can I put the EFI manifold on ANY series 18rg head?
and how would the cams etc have any effect ?
Brendon
Daily - Prado 90series
Work - T908 620hp Cummins ISX
Shed - 1975 TA22 2TG
If you fit the EFI manifold to a non-EFI head then you will need to notch out the top of the intake port so that the injector spray doesnt impinge on the head.
Are you asking how the cams would effect the EFI?
The cam profile will affect the engine in virtually the same way whether it is EFI or non-EFI. The cam profile will affect how you tune your ECU, assuming you are using an aftermarket ECU.
At a guess if the cams are close to stock then the OEM ECU should handle it ok. If you went to 304/304 then you will have a big problem on the OEM ECU
