Results 61 to 65 of 65
Thread: Vp 3800 V6 into hilux - how to
  1. #61
    Default Re: Vp 3800 V6 into hilux - how to
    Quote Originally Posted by Spanner
    how did the convertion go? ive been reading up on what you have done and im thinking of doing it to my 82 hilux have you got any pic's of th convertion process? and how much did it end up costing?
    i went a bit over the top with my conversoin, but the motors being so cheap make the conversion easy. All i will say is the conversion is dickloads easier in a 4x4, a 2wd requires custom sump n pickup. as long as u can weld etc engine mounts arent too bad, i just used a single piece tailshaft and its worked fine...
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
  2. #62
    Feb 2010
    I know this is a long shot in an old thread , does anybody actualy have any pics of this conversion . ie engine mounts , sump .etc. I am doing a VN3800 + T700 into an RN41 2WD dual cab. any pics or advice would be greatly apreciated. i will be grafting the commy dash into the lux to make it easier.
    thanks , Roger . pics to > [email protected]
  3. #63
    roger i grafted the dash etc too. I put auto + power steer on mine too. ill try and get pics together - they are on one of my pc's.
  4. #64
    Jun 2011
    im currently in the process of gettin my vn v6 hilux to fire...., im using a series 1 motor with the auto, i got fuel but no spark at all and no pulse to the injectors..... any ideas? ive replaced all the fuses and relays, it cranks no problem so what have i missed? i used the original wiring harness, kept it complete and just wired it to the original hilux ignition
  5. #65
    Mud Mechanic 1st year Apprentice
    Aug 2006
    tas
    you have disable the imobiliser system, if you take the cpu to a good mechanic or a auto elec they will conect it to a lap top and switch the imobiliser system off.
    i was lucky with my conversion this was allready done other wise i would have had the same problem you have had, the only reason i found out about it was i did heaps of research prior to doing the conversion, check other forum post and web sites
    *If It's Not Toyota, Its Not Tuff Enough*
  1. hilux diff-to-ae86
    By fixeruperer in forum Tech and Conversions
    Last Post: 14-10-2011, 11:22 PM
  2. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  3. Alloy Trays on Hilux/ Cruiser/ Hilux 4 door
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-03-2006, 07:54 PM
