Page 2 of 13 FirstFirst 123412 ... LastLast
Results 16 to 30 of 188
Thread: late 97 on hilux 3rz turbo conversion walk through
    Default Re: late 97 on hilux 3rz turbo conversion walk through
    It has 0 progress from machining the motor and getting the parts needed, lost interest when putting a torque monster into a hilux would need major suspension mods etc to deal with the added go pedal,
    The turbo gear is now in a mates 4x4, goes well and is perfect to drive off road, heaps of power on hand without excessive low down power that would cause wheelspin and/or broken cv's, with lots and lots of low down torque with gearing and ecu tuning.
    3RZFE-T Backyard Mechanic
    Nov 2008
    queensland
    Is it possible to use a fuel piggy back system instead of doing a complet ecu upgrade
    Iam looking at lcengineering and they sell a LCE Pro Fuel Injection Kit #3 (0-30 lbs. Boost) (4 Cylinder)
    which it claims to be a complet stand along fuel management system. The other thing that iam worried about is how do yo tune them. Would it be somthing i could do my self eg simply adjust sytem on the run or would it need dyno time
    Aug 2009
    some great info in here thanks to BeRad and Lance! i have an 04 3rz 2x4, have recently purchased a t3 to bolt on to my gal, i m lookin at a microtech lt10s to b the brains of the outfit n have been lookin at an exhaust manifold form steedspeed in the states, any tips for me? is my choice of ecu good? cheers
    Aug 2009
    some pics of fmic installs on sumthin close to 04 would b awesome to c as well! if anyone has any?
    Nov 2008
    queensland
    willoisme. Iam getting a brand new adaptronic fitted tuned and installed for $2200
    Mine should be done maybe this month if not deff next month. My little gt3582r External will be sucking in small birds and kids soon. as usal everything revolves around on getting everything ready.
    Doing the fuel system this weekend so i'll take some pics. FMIC is the next drama and is gonna be a pain in the arse
    Nov 2008
    queensland
    why must the 03 hilux be so unfriendly for FMIC . Stupid a/c condensor is in the road
    mine has no aircon though which matters, and a relocated battery to the tray
    Quote Originally Posted by Tweak View Post
    Move it
    Quote Originally Posted by WilloIsMe View Post
    Lance ran a lt10s, n rodi on here also runs a microtech, the 3rz are the most basic of motors bar the crank angle sensor which every ecu will accommodate anyway, 6speed????? or similar on here makes a 3rz manifold and does top shelf work, short of that either importing or getting one made from an exhaust shop.
    And you won't need a ignition module, as the 3rz coil packs run internal ignitors so you just need to power them up from one of the outputs via a relay.
    Between the boosted 3rz people on thisd forum alone, there is maps for haltech n microtech that will atleast get you to the dyno or to play with it on road.
    Injectors are another big thing they won't support more than 4 or 5psi of boost.
    Nov 2008
    queensland
    dont realy wanna get rid of the a/c. its tempting to rip it all out. May just have to loop under the radicator support and come up through the engine bay.
    flipping the cooler and going under the support is probably best, or move that cylinder a/c do wacky so you can route the pipes in where i have. I never had a/c so didn't have to remove it, the more luxuries you can keep the better imo.
    Nov 2008
    queensland
    I'll cross the bridge when i come to it. Just gotta finish the fuel pump/surge tank install beofr i do anything else
    May even relocate the cyinder thingy some were else
    Aug 2009
    hey tweak i just finished mounting my fmic its about 600 x 400 fits in pretty easy. haven't put any pipeing on yet or cut holes for it but it sits in behind the grill nicely sits right behind the bar tho, but should still get plenty of air. i just mounted it on a piece of box sitin on the chassiss rails that poke out, i had to lean it in at the top to avoid cuttin the bumper and just pushed the ac lines up as far as i could will just to fit under the ac gear, have u got an exhaust manifold? if so where from n how much??
    cheers 4 the info brad!
    Nov 2008
    queensland
    I bought mine off ebay. its one of those ones from usa but mine was already in aus cost me $200
    Nov 2008
    queensland
    Fur future reference the fuel pump trigger wire is the Blue with black stripe Not the white one with blackstrip.
  1. Travs 3SGE +turbo RWD conversion
    By TRAV-KE55 in forum Tech and Conversions
    Last Post: 08-09-2010, 07:50 AM
  2. SW20 MR2 turbo conversion
    By GaMMa in forum Tech and Conversions
    Last Post: 27-02-2007, 11:38 AM
  3. difficulty Manual conversion in late model chaser or aristo
    By 73ta22 in forum Tech and Conversions
    Last Post: 25-07-2006, 02:33 PM
  4. SV21 Camry + Turbo Conversion.
    By UltraViolentRay in forum Tech and Conversions
    Last Post: 15-03-2006, 08:29 PM
  5. turbo conversion on ae112rlevin
    By mrxplode in forum Tech and Conversions
    Last Post: 13-02-2006, 02:08 PM
