Results 1 to 6 of 6
Thread: 20v - 16v a4age compatibility
    Junior Member Backyard Mechanic cri_ag's Avatar
    Default 20v - 16v a4age compatibility
    ok so the story goes i brought a 20v block that had been fitted with gze pistons ect. in anticipation of a turbo conversion. however i dont wish to run the 20v head, rather the smallport 16v one, so as not to have to worry about distributors, plenums and water lines. now seeing i have a 20v block and a 16v head can anyone see any problem with running a 16v timing belt? also will the 16v oil pump be compatible?
    cheers guys
    craig.
    Default Re: 20v - 16v a4age compatibility
    Blocks are the same, so 16v timing belt & oil pump will be fine.
    i dont see any reason why not.... the only thing i can maybe think of is the oil drain on the smallport 16V on the intake side near cyl 4.... i dont remember if the 20V has this.
    ...... butt scratcher?!
    yep good call the 20v does not, the sump is getting a inlet welded into it either side one for turbo oil return, another for said head drain.
    AGE-16V Automotive Encyclopaedia Dimmy's Avatar
    Sorry to hijack the thread guys, but since it's the compatibility thread i thought i'd ask here
    Im looking at buying a microtech ltx8 with the loom off a mate who's had it in his car for the last 2400km of its life. Now the engine is a 4age 16v whereas i need it for a 20V. Would you know if the loom would have to be changed or can it be used?
    I have been pruned by old man river!!!!!
    ok cheers for the confirmation bigworm!
  1. 1uz/2uz compatibility....
    By joecoolmk2 in forum Tech and Conversions
    Last Post: 13-01-2011, 02:46 PM
  2. AE86 - AW11 parts compatibility?
    By Stomp86 in forum Tech and Conversions
    Last Post: 25-08-2006, 09:19 AM
  3. Coil Pack Compatibility?
    By ra23celica in forum Tech and Conversions
    Last Post: 06-04-2006, 07:52 AM
  4. RA60-65 Compatibility
    By AutoXCelica in forum Tech and Conversions
    Last Post: 07-02-2006, 02:24 PM
  5. Hilux engine/gearbox compatibility
    By blacksmoke_mkII in forum Tech and Conversions
    Last Post: 26-12-2005, 12:15 AM
