Results 1 to 5 of 5
Thread: RA65 22RE Bellhousing vs 1GGTE
    Default RA65 22RE Bellhousing vs 1GGTE
    Hey all, got a quick question.. My mate is converting a RA65 22RE to a 1GGTE.
    He is using his original gearbox, I think its a W55 or W57. But he has noticed the 1GGTE bellhousing, while it all bolts up, is around 5 - 7mm longer.
    Can anyone confirm if thats correct, and if its a problem? I guess in terms of spigot, or the position of the clutch bearing? I've never heard of any 1GGTE - W55/7 bellhousing problems?
    Thanks
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Default Re: RA65 22RE Bellhousing vs 1GGTE
    Its possible that the 1G's crank sticks 5-7mm further out than the 22RE's.
    I know this is the case with JZ motors.
    Ahh ok that is interesting idea.
    User Conversion King
    NWA
    still want the measurements?
    i have both bellhousings
    hello
    As stated, the guy is using a 1G bellhousing to bolt a "W" series gearbox to a 1G-GTE engine. That is as the factory intended, so no drama's.
    An IS200 box I have here, has the gearbox input shaft protruding beyond flush with the bellhousing face. From memory about 5mm.
    cheers Chuck.
    MS51Crown Coupe,
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 10:38 PM
  2. A-series bellhousing to OLD T-series transmission
    By Toycrash in forum Engine & Driveline Conversions
    Last Post: 21-06-2008, 05:24 PM
  3. 1GGTE into RA65 Questions.
    By Ashe in forum Tech and Conversions
    Last Post: 20-11-2006, 08:51 PM
