Page 1 of 10 123 ... LastLast
Results 1 to 15 of 148
Thread: 5MGE into MA61 (changed from 7MGE)
    Question 5MGE into MA61 (changed from 7MGE)
    I need your help guys, I'm trying to weigh up whether it is worth getting an old 7M, re-doing the head/gasket, replacing a few other misc things and using that or whether I should grab a 2J and shove that in their instead. It will be for my MA61 supra.
    I can get the 7M conversion done by an acquaintance for $2k if I supply engine (~$500 but then I need more for re-doing head and other things). 2J might cost me $1200 with ecu/loom but then I'd need more things like a W58? I'm not after massive power or anything turbo, but I would like a bit more than the crusty SOHC 5ME puts out
    Tell me the pros and cons and which way you think I should go and remember, it's always on a tight budget. Thanks guys
    Last edited by RObErT_RaTh; 21-08-2006 at 11:33 AM. Reason: 7MGE not possible anymore :(
    Junior Member Grease Monkey teamdrinkalot's Avatar
    Aug 2006
    Default Re: 7MGE or 2JZGE? (I've got a week to choose!)
    Don't get a 7MGE as their head issue is not worth solving. The amount of money you spend on the 7 to fix the ongoing head problems is far better being spent on the 2J
    Quote Originally Posted by teamdrinkalot
    Its only an ongoing problem if its not fixed properly the first time at which point you must question said workmanship on the car. .
    Depends on your driving style really do you like an engine with a punch in the guts off idle, or do you prefer to rev it out .
    That being said, the 2jzge is a newer motor, has more power out of the box so you are really only ever playing catch up with the 7mge. They still aren't a bad engine though.
    If in doubt power out
    This is me. I own an MA61. With a 7m, I still own an MA61 I like to keep it within the family.
    SHE LIVES!
    Go the 2JZGE. Aside from a smidge more bottom end, the 2JZ owns and only has more potential. If your car is a manual, all you'll need is a clutch/bellhousing/flywheel etc. Yes it will cost more, but it will be a better result.
    2JZ-GE. Do eeeeeeeet.
    I was in the same situation. I could go 7m and not worry about engine mounts, bellhousings, etc. But I realised that the 2jz is a newer motor, and once I got it sorted, if I want to go turbo.... 1jzgte or 2jzgte are not too hard to swap. Also aftermarket parts availability is slightly better. Even oem parts availability is better.
    Teh Massif Dong Carport Converter BlackSupra's Avatar
    wayne just pulled 137rwkw out of his 2jzge and that is factory with bolt ons!!!
    Want to make that power from a 7m and you need to open the thing up with some serious work!
    Here is my website when i did the conversion a few years ago:
    http://www.geocities.com/ifli4u/project2j.html
    go the 2j!
    from economical point of view i think they are more fuel efficient too, so you would make up for the extra cost in the long run.
    Quote Originally Posted by PlacentaJuan
    go the 2j!
    Before microleb I got 10L per 100km on the 7m on city driving too. Post microleb it gets 12-13L per 100kms, but I think I sink the boot abit more and it could do with some fuel being taken out.
    The microleb economy should own factory economy if its tuned right.
    Problem is you CANNOT tune that on the dyno.
    You need to do it on the road.
    tasmania
    i think the 2jz is the go. where's the poll
    sure the 7m would be easier to do, but the 2jz has similar or better economy with more power. nuff said
    beer me!
    Quote Originally Posted by joecoolmk2
    I thought of that after I posted it Try to edit and it won't let me make poll.
    go the 2j!
    Going by the parts on this page, http://www.geocities.com/ifli4u/project2j.html , it will prob cost me $3000 and that's just parts and using my W57. I have a heavy duty clutch and new slave cylinder, would prob replace the master though just incase. Anyways, 3k plus 2k for the actual labour itself is a lot more than I have right now If it's gonna happen it would probably have to happen a lot further down the track when I can have a second run about car and have the MA61 off the road for a lot longer.
    tasmania
    Quote Originally Posted by RObErT_RaTh
    sounds like you've answered your own question then?
    beer me!
    tasmania
    so why don't YOU do some/most/all the labour? it wouldn't be that hard if you can weld, undo bolts, and use your noggin good
    beer me!
  1. Project 7mge to 7mgte %90 done -%10 need help
    By Mk3_supra in forum Tech and Conversions
    Last Post: 12-08-2006, 11:38 PM
