Page 2 of 8 FirstFirst 1234 ... LastLast
Results 16 to 30 of 108
Thread: 1UZ into MX22, more pics now.
    tasmania
    Default Re: 1UZ into MX22, more pics now.
    yay, it's there. how thick is that bit? i mean, do i have to drill right through to the sump, or is is only ~20mm thick then hollow?
    beer me!
    I tihnk its a plug
    Drill, tap, slide-hammer
    tasmania
    what do you mean? isn't the dipstick tube pressed/tapped in? i thought it'd just tap in with an interference fit.
    beer me!
    Yes, but I'm pretty sure you are looking at a plug in the top of the head.
    Drill a small hole in it, tap the hole, put a bolt/screw in there, and use a slide hammer to pull it out.
    At least that is what I understood the setup to be.
    tasmania
    no, it looks like part of the casting, i'll get a pic to show you.
    beer me!
    tasmania
    beer me!
    Nice and Clear!
    tasmania
    here's my alternator tensioner, nothing flash, made it from the 4M tensioner. it's not quite the right radius, that's why the top hole is slotted. i might make it properly later on, at the moment i just wanna get it running. If anyone wants to do this, you'll need a dayco 6PK0750 rib belt.
    beer me!
    tasmania
    Nice and Clear!
    hehe, yeah bit cramped and dark in there. it looks the same texture all over, definately cast.
    beer me!
    Bummer. You'll need to do what I did to the 2JZ to make the dipstick work. Bit of a PITA. I used a threaded brass fitting with an untapped hole in the middle. Tapped a hole I drilled into the alloy corset of the sump and pressed some aluminium tube into the hole in the brass fitting. Then I gradually cut the top end of the aluminium tube till the dipstick poked thru to the right amount (when you compare it to the Soarer dipstick/sump). Make sure you make the appropriate cutout in the baffle plate before you bolt it all back together with silastic.
    Hey, what are you doing for the oil filter block? You using a Crown one or will the Soarer one clear the Mk2 subframe?
    tasmania
    Quote Originally Posted by gianttomato
    i'm making a custom one, but i haven't looked at a soarer one. where do they stick out? the one i got(celsior from what i can tell) stuck out towards the front and the filter fouled the swaybar.
    i almost forgot that the dipstick would need to have a bent tube cause of the different sump location. thanks for pointing that out, would've had fun trying to get the dipstick in... tap tap, what the...
    does anyone know the t/c stall speed of the crown? i'm lookin at getting a 3000rpm stall t/c.
    beer me!
    Soarer ones stick out to the front.
    Celsior ones point towards the factory mounts.
    I had to make a custom one to miss the chassis. The fittings point to the front.
    tasmania
    now i'm really confused, everything else on this motor suggested celsior, but if this is correct it might be a soarer motor. so, what colour are the soarer injectors? mine are grey. and my injector rails are machined alloy casts. and weren't those exhaust manifolds celsior ones?
    beer me!
    Dark Green are Soarer
    Light Purple are Celsior
    Celsior oil filter mount (can just see it)
    http://hotrodders.com/gallery/data/5...10_Medium_.jpg
  1. 1UZ bottom end bits
    By mrshin in forum Tech and Conversions
    Last Post: 25-07-2006, 07:58 PM
  2. 1uz Ms65. I Need Some Advise
    By AZZTOY in forum Tech and Conversions
    Last Post: 19-03-2006, 03:43 PM
  3. MX22 and MX13 conversion
    By cyprus73 in forum Tech and Conversions
    Last Post: 13-02-2006, 09:51 AM
  4. 1UZ into RA65 - Drift car.
    By nihilism in forum Tech and Conversions
    Last Post: 08-02-2006, 10:16 AM
