Page 6 of 6 FirstFirst ... 456
Results 76 to 80 of 80
Thread: Engine Conversion. 2JZ-GE into MS53 Crown
  1. #76
    Brisbane
    Default Re: Engine Conversion. 2JZ-GE into MS53 Crown
    Just dragging this up from the dead, came across it while I'm trolling MS55 stuff.
    Only reason I post is that the quarter mile time seems a bit on the soft side (tried to find a nice way to say it, this really is an impressive car!)? Sure with a bit better launch it would have gone into the high 15s quite easily, but is this representative of how a 2JZGE really goes? If so I have to say it seems a bit disappointing on paper (although no doubt transformed the car!)
  2. #77
    Oct 2010
    victoria
    Quote Originally Posted by Shifty View Post
    Yeah the GE is definitely no fire breather, turboed they are animals and able to make big power but NA they are lethargic.
  3. #78
    Brisbane
    After looking at pics again I do note now that it's an auto, which won't have helped the launch or MPH.
  4. #79
    Hi Shifty, Stock 2J and Stock Auto and Torque convertor with stock solenoids and line pressures in the auto and no line locker fitted either
    The MS53 is 1500+ KG of wagon so wth tyhe 2J package as the factory intended (soft gear shifts and all) it went well for what it is. A shift kitted Auto would have done noticeably better
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
  5. #80
    May 2010
    Moscow
    As for low 16's , assume it's ok for non-vvti with 4a/t.
    My car (1470kilos with driver and fuel) has 1jz-ge vvti + 5a/t . With leaky injectors, no CAI, some other minor things it did 1/4 in ~16.5
    I'd do comp test just in case. ANother thing worth checking is fuel trim ("vf" pin in your diag. conn.). If it's low in idle and gets more "normal" as you increase rpm, it's worth to check out if your injectors are leaking (more than 1 drop in 1 minute @ 3bar)
  1. Toyota Crown MS53 Crown Custom Wagon
    Last Post: 23-06-2011, 11:44 AM
  2. MA70 --> JZA70 Conversion
