Page 11 of 11 FirstFirst ... 91011
Results 151 to 164 of 164
Thread: 3VZ-FE V6 into SW20 MR2 (56k be warned!)
  1. #151
    Junior Member Backyard Mechanic greywolf's Avatar
    Nsw
    Default Re: 3VZ-FE V6 into SW20 MR2 (56k be warned!)
    Fit an aftermarket LSD to a open diff S54 ?
  2. #152
    Junior Member Backyard Mechanic Jaemus's Avatar
    i wasnt aware that was possible?
    1992 MR2 GT turbo
    2009 Lexus IS-F
    Built Australia's first V6 MR2 >> Winner: "I'd Drive It" award - Toyfest '07
  3. #153
    Nsw
    Hence the question mark
    Throwing it out there as a possibility ?
    Having worked in an automatic transmission shop has made me realise I would love to specialise in manuals/diffs.
    Ninja Edit : Ofcourse it's possible, that's why I suggested it
  4. #154
    of course you can... makes 1/2 of the products listed here useless if you couldn't http://www.kaazusa.com/partinfo_japan.html
  5. #155
    Junior Member 1st year Apprentice v8gz20's Avatar
    Jun 2008
  6. #156
    awesome, thanks very much guys!
    there you go then
    TRD is pretty freaking expensive but nevertheless various options means ill be able to find one at a good price somewhere
    1992 MR2 GT turbo
    2009 Lexus IS-F
  7. #157
    always looking like a Grease Monkey fibrewizard's Avatar
    hey man.... long time no chat.......
    i got my v6 in and running..... ..............
    Q?...... what temp does your 3vzfe sit on........ mine is anywhere from 85 -95....... so trying to figure if water pump is fukt.........but its not overheating just seems hot.. is all
    grant......
    2012 GT86
    V6 powered 5th gen celica. Sadly moved on to build below
    91 st185 aus delivered, V6 turb project,
    2015 Kun26r hilux
  8. #158
    hey man
    i dont have a water temp gauge that shows me in exact degrees but, when everything was running well, the factory gauge goes up to the usual spot it did with the 3S and sits there without moving even slightly
    im using a 5S-FE thermostat btw
    1992 MR2 GT turbo
    2009 Lexus IS-F
  9. #159
    Quote Originally Posted by Jaemus View Post
    hey man
    sweet thanks...... turns out my thermostat.... wasnt completely opening..... so removed and cut out the centre of it and re-installed.......... should help it out a little till i can get it properly sorted........ at least its not restricting flow too much now.......
    2012 GT86
    2015 Kun26r hilux
  10. #160
    no worries dude, yeah hope you get that sorted and there's no BHG!
    1992 MR2 GT turbo
    2009 Lexus IS-F
  11. #161
    Jan 2009
    adelaide, SA
    i have a kazz 1.5way in my mr2 they cost about 1.5gs and a nother $1000 to put in. Yeah bit expensive but worth it. i have had it for 2 years now and still going strong.
  12. #162
    Jul 2009
    Paul woods has done some experimenting and the ZZW30 factory helical LSD fits into the S54 box. IF your able to locate a second hand spyder box, it might be a cheap option.
    http://forums.twobrutal.com/showthread.php?t=11589
    Or mini spool !
  13. #163
    you wouldnt happen to have a spare rear gearbox mount from the MR2 would ya....
    im going ahead with e153 gearbox conversion in the celica and need another mount to bolt to gearbox... on the rear of engine.... so driveshaft side of box.... front one i can use 184 mount...... top of gearbox/passenger side is a gt4 mount..... but the rear one i believe is a MR2 mount......
    2012 GT86
    2015 Kun26r hilux
  14. #164
    thanks angelmon and knightrous, interesting info!
    fibrewizard: im afraid i dont have a spare mount, you could try the MR2 forum
    http://mrtwo.mine.nu/default.asp
    1992 MR2 GT turbo
    2009 Lexus IS-F
  1. SW20 MR2 turbo conversion
    By GaMMa in forum Tech and Conversions
    Last Post: 27-02-2007, 11:38 AM
  2. How-to: Converting an MR2 gearbox to FWD (SW20 to ST162)
    By buck naked in forum Tech and Conversions
    Last Post: 27-12-2006, 06:22 PM
