Results 1 to 6 of 6
Thread: Tuner for 20v in Sydney
    Mar 2014
    Default Tuner for 20v in Sydney
    As title states. Looking for someone to tune a 20v 4age with haltec e8 and Yaris coils
    Mar 2014
    Default Re: Tuner for 20v in Sydney
    This is a long shot. Wired up the haltech. Using the old tune (which ran). Now having cops. And wired into the factory fuel pump relay. Car starts. Idles for 15secidnds then turns off. If I give it any throttle it turns off.
    Anyone have any ideas? I don’t think haltech support such an old ecu
    Dale at Castle Hill Exhaust has history with 20v Toyota engines and is a Haltech guru. You won’t go wrong with him.
    He can tune old Motec ECUs so I doubt an older Haltech would be a challenge.
    Is your fuel pump running when the engine shuts off after 15 seconds?
    Sent from my iPad using Tapatalk
    Mar 2014
    Cool. Will try. Does dale work saturdays?
    Quote Originally Posted by bazz1984 View Post
    I think he does by appointment. Give him a ring and book it in. Ph: (02) 9680 2777
    What model is your ecu?
    If you do get it tuned make sure you ask him to set up the vvt switch over point (assuming you have stock cams?)- consensus is that the vvt should be switched back off at higher rpm for maximum power. Pretty easy to check on the Dyno - run with vvt on and vvt off and look for the crossover point in the power curves.
    I’d be interested to know what rpm works for you - silver top or blacktop? Any mods on your engine?
    Mar 2014
    It’s a e8. I’ve wired the vvt. They say to then it in around 2ish then off at 6ish. It’s a stock st with 1nz cops and a ra10 for the reluctor signal
  1. 1jz gte vvt-i tuner
    By Indelible in forum Tech and Conversions
    Last Post: 25-02-2012, 03:42 AM
  2. Best EMS tuner in Melbourne?
    Last Post: 30-06-2009, 05:39 PM
