Results 1 to 7 of 7
Thread: ZZE-122 ECU rev limiter
    Aug 2018
    Default ZZE-122 ECU rev limiter
    Does anyone know if theres someone out there that can disable the rev limiter and still using the factory ZZE-122 Denso ECU , as it cuts in right on the redline of 6,400 rpm
    I know people will say that 6,400 rpm is plenty as its max power comes in at 6,000 rpm but when racing the car we are have change gears in the most inconvenient spots on the track
    ( in one section part we go from 2nd to 3rd and straight back to 2nd again which affects lap times )
    If we could get it to the high 6,s it would make a huge difference
    Default Re: ZZE-122 ECU rev limiter
    On the 7m ecu we used to swap out the crystals for higher frequency ones to bump up the rev limit, may or may not help yours
    Never late in an x8
    Aug 2018
    Quote Originally Posted by andrew_mx83 View Post
    Did you swap the crystals yourself or did you get someone to do it and where did you buy the higher frequency crystals from
    They came from RS components and yeah we fitted them ourselves. Would pay to have a couple spare ecus to practice on first depending how handy you are with the soldering iron
    Never late in an x8
    Aug 2018
    Thanks for the info and yes Iam already getting another one to trial first, also was your ECU plug and play or did it have to be programmed to the car
    Victoria, Mt Macedon
    I'm purely quoting internet "know-how" here, but apparently the earliest 2ZZ ECUs had a higher fuelcut. Then after some engine failures due to missed shifts and over-rev the fuelcut was dropped for later generations.
    May or may not be true, but it sounds like an early ECU (if the other pinouts are compatible) could sort you out.
    Quote Originally Posted by Hen View Post
    There are differences in rev-limit and lift engagement amongst the various years/markets for the 2ZZ, as well as differences between Corolla and Celica.
  1. NO rev limiter on 1jz after conversion but wanted
    By naten in forum Tech and Conversions
    Last Post: 28-07-2008, 05:15 PM
  2. greddy speed limiter installation
    By PlacentaJuan in forum Tech and Conversions
    Last Post: 04-02-2008, 12:05 PM
  3. 20v rev limiter
    By 4agte in forum Tech and Conversions
    Last Post: 17-08-2007, 09:27 PM
  4. Why is my 2jz-gte hitting rev limiter?
    Last Post: 11-10-2006, 01:39 PM
  5. 1JZGTE problem, rev limiter/ idle
    By GZP51 in forum Tech and Conversions
    Last Post: 24-09-2006, 03:38 PM
