Results 1 to 3 of 3
Thread: Brake Master Cylinder Issues TA22
    Oct 2011
    vic
    Default Brake Master Cylinder Issues TA22
    Hi Everyone,
    i have had a look through the forum and have not been able to find any information on the MC conversion i have under gone.
    My original one had the seal let go, so i replaced it with a newer Camry MC which bolted straight up just had to manipulate the lines to fit.
    Now i am having the issue of the Brake pedal falling to half way then it because ridiculously hard and does not lock up the brakes as if it where original.
    i have checked the vacuum of the booster seems to be OK and is the same as my other TA22. i have bled the brakes correctly.
    any suggestions on what to look for?
    Dec 2015
    Michigan
    Default Re: Brake Master Cylinder Issues TA22
    Sounds like the booster. If you pull the vacuum hose off, do you hear air rushing in the booster? There should be a check valve in the system to maintain vacuum. Davew7
    Oct 2011
    vic
    Yes i have tried that and i cannot hear any air rushing out of the booster, but when the pedal is pressed i can hear air escaping from somewhere. not sure where though.
  1. TA22 Brake Master Cylinder options...
    Last Post: 09-04-2022, 06:31 PM
  2. TA22 Master brake cylinder
    By Invid in forum Tech and Conversions
    Last Post: 14-08-2009, 08:11 AM
  3. ta22 brake master cylinder
    By c budge in forum Tech and Conversions
    Last Post: 03-08-2007, 06:36 PM
  4. Replies: 3
    Last Post: 06-07-2006, 07:11 PM
