Results 1 to 8 of 8
Thread: 1G-GTE Direction Suggestions
    Jul 2015
    OH - Ohio
    Default 1G-GTE Direction Suggestions
    Good Afternoon all. I have a 1988 Soarer here in the states with a 1G-GTE in it, which was never sold here. Car runs good when I got it but the turbo in the rear was completely toast so I went single 30r and a new exhaust manifold with an external gate. I also replaced the factory fiber head gasket with a 1G-FE MLS head gasket and 2JZ ARP main studs for head studs. I also ditched the factory intake and butterfly secondaries setup for a FFIM with a 75mm throttle body. Everything else is stock inside the head and bottom end but everything outside is modded to work better or make more power including a standalone ECU setup.
    My main question is where to start with boost, what can the 1G take without breaking immediately and still be reliable. My thoughts so far is to start at 14psi on pump gas and work up from there and go E85 at some point.
    Jan 2011
    Default Re: 1G-GTE Direction Suggestions
    1G performance parts can be a bit limited and as much as my 1GGZE is fun, you might be better off getting a 1JZGTE. A bit newer and a lot more parts.
    That said, plenty of people on here are making decent power on stock internals with a modern single turbo.
    http://www.toymods.org.au/forums/forums/47-Dyno-Results
    This is not a bad place to start. Just search the forums for 1ggte. Lots of people have them with single conversions.
    Jul 2015
    OH - Ohio
    Quote Originally Posted by masterofsinanju View Post
    Most of the performance mods I have made myself or made from some other engine model. I am trying to post a picture but the site keeps saying it fails to upload. At some point I will go 2JZ but for now the 1G is my interest.
    Jan 2011
    Load your image up to something like IMGUR and use the forum links they provide.
    Lots of folk on here over the years getting over 200kW out of 1ggtes.
    Lots of gen one and two celicas on here with 1ggte in various configurations. Go have a dig through the members rides forum as well.
    Jan 2017
    Kuala Lumpur
    Good to see the 1G GTE getting some attention, are you on the z20 FB group ?
    Jul 2015
    OH - Ohio
    I am hoping to make over 300kw as you guys measure it or at least 400HP, if I dont I will spray nitrous until it does.
    Quote Originally Posted by alcyon View Post
    I am on the international group and the US group. I like this engine, it has its downfalls like anything else but I like it.
    Jan 2011
    At those sort of power levels you are going to need to make additional mods. Changes to oil flow to avoid spun bearings is one I'm sure I've read about. There is information here that you should search for. It's a big ask (and likely cost) to get that power out of a 1g. But I'm really keen to see how you go.
    Jul 2015
    OH - Ohio
    It is not so much a oil pressure problem as it is a volume problem. If I get low on oil level then the chance of spinning a bearing is super high and I have taken precaution with that by adding an oil cooler out front. Keeps the oil cooler and adds some capacity even if it is slight.
  1. What is the oil flow direction in the oil filter?
    By JoJo in forum Tech and Conversions
    Last Post: 15-12-2007, 12:10 PM
  2. Intercooler flow direction
    By Biggo in forum Tech and Conversions
    Last Post: 10-01-2006, 08:53 PM
  3. 3t rod tang, which direction from front?
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 23-12-2005, 05:45 PM
