Results 1 to 4 of 4
Thread: Can anyone identify "Jun" sgte valve springs???
    Aug 2016
    Yorkshire
    Default Can anyone identify "Jun" sgte valve springs???
    Hey all,
    Bit of a weird one but here goes...
    Guy i bought my engine off (3sgte rev 3 head) (in parts) said his brother built the engine originally and it had a "Jun valvetrain".
    Retainers n valves looked stock....
    When I did the valve stem seals (looking for a ghost vac leak) i took a pic of one of the springs. Can't figure out how to post the pic on here...
    Its bronze coloured and fairly meaty looking (doesnt hell I know lol)... Is the spring dia thicker on uprated springs? Anybody know the stock ones look like? (To compare).
    I'm running high lift cams n need to know what they are!
    Thanks again
    Chris
    Aug 2016
    Yorkshire
    Default Re: Can anyone identify "Jun" sgte valve springs???
    Posted a pic as my profile pic. 3sgte gurus... Look stock or aftermarket?
    Thanks
    Chris
    uprated springs can either have more meat.. or less length (ie, less turns)
    your best bet may be to get them measured?
    for example
    http://www.junauto.co.jp/products/va.../index.en.html
    Set Length: 34.5mm
    Lift Length: 24.5mm
    Set Load: 30.0kgm
    Lift Load: 72.8kgm.
    here, 94 celica(?) 3sgte springs are:
    http://bgbonline.celicatech.com/93ce...rhead3sgte.pdf
    Installed tension:
    201 – 236 N (20.5 – 24.1 kgf, 45.2 – 53.1 lbf )
    at 34.4 mm (1.354 in.)
    so JUN springs should be significantly more?
    Aug 2016
    Yorkshire
    Oldcorrolas,
    dude this is EXACTLY what I wanted to know, thanks so much! Gonna take these out again n measure em! If there are stock I'll be getting some HKS ones payday with titanium retainers while I'm at it! Thanks once again.
    Chris
  1. ANOTHA ONE - non-vvti 1JZ-gte out of a JZA70 breaks up under WOT ""HELP MEEE""
    By jdesign in forum Engine & Driveline Conversions
    Last Post: 25-09-2017, 10:32 PM
  2. Replies: 8
    Last Post: 02-11-2013, 05:49 AM
  3. ST162 - "GTR" vs "SX" any differences?
    By XiL3D in forum Tech and Conversions
    Last Post: 06-07-2007, 11:03 PM
