Results 1 to 3 of 3
Thread: Jzz30 map sensor
    May 2017
    Default Jzz30 map sensor
    I have bought a 1jz jzz30 non vvti engine that I am looking to transfer into my corona. After getting a auto electrician to have a look I require a map sensor as the one I have on this engine isnít originally from this engine(causing me issues).
    I know this site has many forums for this, some saying you can use any 1jz map sensor or even use 2jz map sensors, but also found many forums saying this is all crap you canít do that.
    Can anyone help me with a correct answer? as most the forums 5 years old now. Iím struggling to find a place I can get the map sensor so hopefully there is another way?
    Jan 2010
    Default Re: Jzz30 map sensor
    Part number should be: 89420-24040
    According to ToyoDIY, part number is exclusive to JZZ30, so not the same part no. as JZA70 or the 2JZ. Appears to be out of stock on Amayama.
    As far as I understand, the difference between this one and the others (JZA70, 2JZ, etc) is in the bracket and they actually output the same (0-5v 2 bar sensor) so in theory, the JZA70 and 2JZ MAP sensors (including the boost gauge sender on vvti models) should be pretty interchangeable...
    May 2017
    Cheers Daddio, I'll order me a 2 bar sensor and hopefully everything will be running smoothly
  1. Replies: 4
    Last Post: 25-07-2014, 11:11 AM
  2. JZZ30 a340e speed sensor wiring into MX83
    By Cressii in forum Tech and Conversions
    Last Post: 17-03-2012, 01:38 AM
  3. jzz30 1jz mapsensor swap to a 2jz m/sensor??
    By gsrt085 in forum Tech and Conversions
    Last Post: 29-01-2008, 08:31 PM
  4. Oil Level sensor JZZ30 Soarer
    By rogue-vl in forum Tech and Conversions
    Last Post: 26-04-2007, 08:44 AM
  5. jzz30/A340E speed sensor issue
    By lumpy in forum Tech and Conversions
    Last Post: 20-01-2006, 01:28 PM
