Results 1 to 5 of 5
Thread: 3tgteu largest compatible cam shafts ???
    Feb 2018
    Default 3tgteu largest compatible cam shafts ???
    what are the largest compatible cam shafts for the toyota 3tgteu ???
    Sep 2007
    Georgia
    Default Re: 3tgteu largest compatible cam shafts ???
    Here is an ad from 1981-1983 for HKS Camshafts which is an after market distributor of performance products. Depending on popularity, limited numbers of that particular series were sold or a hidden treasure if found in any vehicle that had been modified during the 3TG's limited production run. The Unicorn cam series.
    This information was new then and may or may not apply to todays performance standards. Remember that the 2tg camshafts fit that particular head, except for the distributor drive gear. Cams can be re-ground to what ever duration the user request.
    Feb 2018
    sorry so the list cuts of at 288 ? is that the largest that is compatible and if so what are they out of ?
    thanks
    Sep 2007
    Georgia
    Quote Originally Posted by Branx101 View Post
    thanks
    3TG
    2TG
    Compare the two engine series and note the differences. This is not a major question for folks who own this engine. Sourcing ignition parts is harder to find then the after market camshafts. Good Luck in your search.
    Aug 2009
    thanks
    The engines are from a Japan production TA63 Carina, 1983 model. Vin numbers start with TA63-ACMQZ or TA63-AEMQZ both for manual models. Cams don't know, you may have to get yours reground which involves building lobes up with weld which is why most places charge about $560 pair.
  1. Replies: 0
    Last Post: 12-07-2017, 11:49 AM
  2. Largest throttle body when keeping 4AGZE OEM inlet manifold
    By Valkyrie in forum Tech and Conversions
    Last Post: 19-12-2013, 09:33 AM
  3. Largest Springs That Will Fit The Rear Of An ST141
    By MOOKIE in forum Tech and Conversions
    Last Post: 13-08-2009, 04:04 PM
