Results 1 to 7 of 7
Thread: 2JZGE VVTi DLC3 (OBD2) Connector Issue
    May 2017
    Columbus, Ohio
    Question 2JZGE VVTi DLC3 (OBD2) Connector Issue
    Hello,
    I am wiring a 2JZGE VVTi (from manual 02~05 IS300) into an older chassis.
    The car starts and runs just fine however it's in limp mode and throwing a CEL.
    I've wired the OBD2 connector to the best of my ability but can't get any data pulled. It powers up my scan tool but no parameters/codes are displayed.
    What are the minimum pins that need pulled? I think (from memory, sorry; at work) I skipped on A/B, TS, and TC. I wired TAC, BAT, SG, CG, WFSE, and SIL. SG and CG are wired to a common ground although IS300 is grounded to intake manifold and chassis, respectively.
    I *think* the TC is my issue since it traditionally turns on test mode in older engines (pre-OBD2) so I'm curious if this needs grounded or something.
    Any insight would be appreciated!
    Thanks!
    Sam
    I drive autos because I can't shift
    2005 Lexus IS300 - Supercharged
    1994 Toyota Land Cruiser
    1991 Mazda RX7 - NA-T auto project
    Default Re: 2JZGE VVTi DLC3 (OBD2) Connector Issue
    With my JDM 2JZGTEVVTI grounding TC turns on test mode. If your motor is JDM you need a JDM scanner
    Jealousy is a curse
    May 2017
    Columbus, Ohio
    My ECU is USDM-spec but I think the difference is just protocol. That being said, are saying TC need to be grounded to "enable" the data stream? I'm thinking the OBD scanner might simply ground TC via the ground pin SG or CG? Any insight?
    Ground TC and the error codes will flash the CEL
    Jealousy is a curse
    May 2017
    Columbus, Ohio
    Thanks for clarifying, madmont
    I've done some more searching and I'm going to try your suggestion; hopefully I can make sense of the codes. It looks like you were discussing with wilbo and some other guys about this in the past.
    I'm still frustrated that my obd connector isn't working. I want to access the data stream for trouble shooting other problems.
    May 2017
    Columbus, Ohio
    One more request:
    Does anyone have a pinout for the OBD connector with orientation noted (back of coupler/harness-side or front of coupler/connector-side)? I worry that maybe I have it wired backwards or something? Unfortunately, I have not had a chance to mess with the car since I originally posted but I'd like to double-check my notes. Looking around, the orientation is ambiguous in pictures and the manual I have isn't much help on this one either. Thanks in advance!
    May 2017
    Columbus, Ohio
    Hi all,
    Just an update. I let this sit for awhile and came back to it last week. Ultimately, I wired up the connector per the IS300 Overall Wiring Diagram and left out A/B and TS connections since those systems won't be added to my MX62. It works great! I'm honestly not sure what I was doing wrong back in February. Anyways, just closing the loop. Thanks again for the responses!
  1. Tarago ACR30 2001 OBD2 connector
    By astroboypaul in forum Tech and Conversions
    Last Post: 22-01-2017, 07:04 PM
  2. 2jzge vvti Code 59.....Help
    By chris78 in forum Tech and Conversions
    Last Post: 31-07-2012, 05:08 PM
  3. 2jzge vvti TPS question NEED HELP
    Last Post: 31-07-2012, 05:31 AM
  4. Replies: 7
    Last Post: 29-04-2011, 06:52 PM
  5. OBD2 Connector problems
    By webby293 in forum Tech and Conversions
    Last Post: 31-08-2010, 10:09 PM
