Results 1 to 3 of 3
Thread: What are thread dimensions for the 18RG Timing Chain OIL Nozzel?
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Default What are thread dimensions for the 18RG Timing Chain OIL Nozzel?
    Hi
    I have a damaged thread in my 18RG Yamaha head and need to re-tap the 9.5 mm hole with the correct thread that suits the OIL NOZZEL.
    Can anyone tell me the thread dimensions please?
    The Nozzel measures 9.5MM and might be BSP 1/8th
    It should be tapered gas thread but its not quite like the fittings in the inlet manifold that feed the power brake booster, nearly but not quite.
    I think they are 9mm not 9.5.
    a 10mm x 1.0 fine sort of seems close but the thread on Nozzel is tapered 0.5mm
    But I need the thread dimensions so I can buy a tap if such a tap exists.
    Going to see plumber so see if any gas thread tapered fits
    The part number for the nozzel is 90072-73103 and available from Japan for about $10 plus postage.
    Has anyone fabricated one ??
    What size holes di you drill?
    Thanks for looking
    email vk3zaz at gmail.com if you have any data I can use.
    1968 RT40S Corona 1600S series II (restore in progress)
    1973 RT104-MQFG 012604 Corona GT JDM (Owned since 1976 242000 km)
    1989 ST185-BLMVZ-0007199 Celica GT4 JDM (unmolested classic 95000 km)
    2012 ZN-6 86GT (shed find 5000 km in 6 years)
    Default Re: What are thread dimensions for the 18RG Timing Chain OIL Nozzel?
    May be 1/8 NPT . What is the tpi?
    Jealousy is a curse
    Sep 2007
    Georgia
    So Thread pitch gauge will not solve this question?
  1. SW Motorsports 18RG Upper Timing Chain Tensioner
    By rawb in forum Tech and Conversions
    Last Post: 17-03-2014, 04:48 PM
  2. 18rg cam/timing chain.
    By keseventy in forum Tech and Conversions
    Last Post: 23-01-2012, 07:44 PM
  3. What timing chain to use?? (18rg)
    By ra_28 in forum Tech and Conversions
    Last Post: 12-11-2008, 09:51 PM
  4. timing chain tensioner 18RG
    By spy in forum Tech and Conversions
    Last Post: 14-02-2007, 06:46 PM
