Results 1 to 4 of 4
Thread: TA22 Tie rod end and Pitman arm
    Oct 2017
    Tasmania
    Unhappy TA22 Tie rod end and Pitman arm
    My 1974 TA22 had to go over pits to transfer registration to Tasmania; the report said RH inner tie rod end and pitman arm had to be replaced. I've got the parts and I've got the car jacked up and on axle stands.
    I've got the cotter pins out, nuts off etc but that's as far as I can go.
    The guys on YouTube just rip out the pins and nuts, turn the crown nut upside down, give it a bash with a hammer and everything comes off.
    The tie rod ends etc I've got are nothing like the YouTube yanks are demonstrating/changing and the pitman arm crosses under inner the tie rod, which makes getting any swing with the hammer at either of them impossible. Tried using a three clawed puller but can't get it to grip.
    I took a bunch of photo's but they refuse to upload.
    Can anybody give me a hand here?
    Aug 2009
    Default Re: TA22 Tie rod end and Pitman arm
    Quote Originally Posted by TasTA22 View Post
    Supercheap have balljoint breakers and most parts stores carry them. Unluckily can't add image, just google balljoint breaker. They have two levers pivot together, one has a forked end other a thick flat end then other end has a bolt to tighten jaws together before hammering back end to act as a wedge.
    Forgot to add make sure you check position of pitman arm on steering box shaft before removal. I usually put mark on shaft and old arm before removal, then put both pitman arms together and copy mark onto new arm. Saves a lot of hassle later if steering lock is correct now.
    Oct 2017
    Tasmania
    Thanks for that. I've managed to source 2 x separate tools for the job and hopefully they will get the old tie rod and arm out.
    Sep 2017
    My personal experience, I have had to cut the god damn fu$@ng thing with the grinder. No amount of penetrating oil plus appropriate tools could help me.
    Tie Roda aren't so much the problem, it's the pitman arm on the steering box that's the real (insert worst swearword here)
    Tapered splines have to be the worst things ever invented.
  1. 1989 ms130 crown pitman arm
    By rhys80 in forum Tech and Conversions
    Last Post: 09-11-2015, 11:27 PM
  2. UZS131 Crown Pitman Arm... Where to buy?!?
    By dark.sky in forum Tech and Conversions
    Last Post: 24-10-2013, 01:56 PM
  3. Longer idler + pitman arms on ke20 - what can i use?
    Last Post: 28-05-2013, 02:08 PM
