Results 1 to 9 of 9
Thread: 2005 and on Hilux diffs
    Aug 2016
    South Africa
    Question 2005 and on Hilux diffs
    Hi folks
    What (letter) series of differentials is fitted to the rear of 2005 – 2015 Hilux utes?
    Is this the same differential used in H200 HiAce vans?
    I know older Hilux utes were fitted with G-Series (8”) diffs.
    Does the crown wheel and pinion from a 2005-2015 Hilux, fit in a G-Series, do they also have 200mm crown gears?
    Regards
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default Re: 2005 and on Hilux diffs
    FWIW I fitted a complete 2006 Hilux different centre into an RN25 rear end. Diff housings are different between the two and tail shaft flange does not swap over so tail shaft needs to be modified to fit.
    Sep 2009
    I think it's an a series type diff so supra gears may be similar.
    Quote Originally Posted by Xauterus View Post
    JZA70 maybe. These days take no notice of the "A Series" designation
    Jealousy is a curse
    Sep 2009
    No. JZA80 have an a series diff. Jza70 is the same gears as toyota 86, is200 and hilux g series.
    8 inch diffs also come in the likes of MX83 JZX90 JZX100 Jzx81
    Jealousy is a curse
    Aug 2016
    South Africa
    If the 2005 and newer Hilux differentials aren't identified by a unique letter code, can anyone then confirm that they are also 8 inch?
    Have an 8 inch/200mm diameter crown gear?
    Interesting, would a LS unit intended for an IS200, then fit a Hilux G-series diff?
    Quote Originally Posted by madmont View Post
    What size diff comes in a RX/MX 61/73?
    [QUOTE=IndianaJones;1618588]
    i doubt it
    IS300 maybe
    Jealousy is a curse
    Sep 2009
    I think the hilux has larger axles
  1. hilux diffs
    By goffre1 in forum Tech and Conversions
    Last Post: 16-10-2016, 07:25 PM
  2. 2005+ Hilux diff centre into RN85
    By spectral in forum Tech and Conversions
    Last Post: 01-02-2011, 09:49 PM
  3. knock in a 2005 sportivo
    By bluehawk in forum Tech and Conversions
    Last Post: 12-03-2009, 10:27 PM
  4. ToyotaFest 2005 - Sun 2nd October.
    Last Post: 15-02-2006, 10:47 PM
