Results 1 to 8 of 8
Thread: 1uz cold starting
    Jun 2016
    Default 1uz cold starting
    help i have a problem starting engine when cold temperate climate worst in the morning but after sitting for an hour still takes a few trys
    Sep 2017
    Default Re: 1uz cold starting
    more specific info needed.
    hard to crank? or
    good cranking but no bang? or
    good crank good bang but no idle?
    Jun 2016
    Quote Originally Posted by rebuilder86 View Post
    hard to crank? or
    good cranking,,,, first i thought fuel pump fuel leaking back but today it was hot and it started up second go ///// do these have a cold start sensor mybe still on wrong track/////
    Feb 2007
    Timaru
    Yes they do still have a brown thermo-time switch and a cold start injector, and like 99% of them, the thermo-time switch will be faulty.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Jun 2016
    what do you mean cold start injector thanks
    Feb 2007
    Timaru
    there is a single injector that operates only while cranking and cold,
    From google pictures it looks like it is in the center of the manifold underneath.
    It is controlled by a thermo-time switch, which looks like a large brown temp sensor.
    - KE70 Corolla Dx -
    Jun 2016
    Quote Originally Posted by DX20VT View Post
    thanks heaps
    Dec 2015
    Michigan
    There is also a good chance that the cold start injector is bad. Since both the injector and thermoswitch are not exactly cheap, verify that you are getting current to the injector first while cranking over the engine. 2nd check the wire from the injector to the switch. If you have a VOM, the injector should read between 3 to 5 ohms and the thermo switch 10-5 on the first pin and about 6 ohms on the 2nd pin. If they check out within the resistance range then try cleaning the injector. [lots of cleaning injector stuff on-line] Just apply 12V to the injector while using carb/injector cleaner before replacing either of the parts. The kicker is finding a metric fine thread fitting that will screw into the cold start injector body. I used an old M/C float check valve and epoxied the cleaner straw into the center of the check valve body. Also inspect and clean the screen on the inlet side of the injector. Dave W7
  1. AE92 4AGE trouble starting cold
    By Jesse_RE in forum Tech and Conversions
    Last Post: 24-03-2010, 03:21 PM
  2. Intermittent cold starting delay, 3S-GE
    By Andrew162 in forum Tech and Conversions
    Last Post: 05-12-2009, 04:48 PM
  3. 1JZ not starting
    By Gary in forum Engine & Driveline Conversions
    Last Post: 30-01-2008, 10:27 PM
  4. Need help starting my 2TG!
    By sleeky in forum Tech and Conversions
    Last Post: 22-09-2006, 11:13 PM
  5. 4AGE not starting correctly 5-10 times, then starting correctly?
    By phrostbyte in forum Tech and Conversions
    Last Post: 30-01-2006, 06:55 PM
