Results 1 to 4 of 4
Thread: A340e auto trans with 4.556 diff question
    Jan 2017
    W.P
    Default A340e auto trans with 4.556 diff question
    I have GZ20 soarer with the above mentioned AT and diff, does anyone here know the size of the drive gear attached to the propeller shaft output and the speedo gear tooth ? I need this info to calculate the tooth on speedo gear if I swap GB or diff. Thanks in advance and I promise to share my calculations here if anyone needs them.
    Default Re: A340e auto trans with 4.556 diff question
    22:6..............
    Jealousy is a curse
    Jan 2017
    W.P
    Thanks. From my longwinded calculation and with the gearset madmont has given, i found that for 1km traveled, the speedometer sensor turns 137 times. Or in simpler terms, one turn of the wheel, 3.66 turns of speedometer sensor (which is ratio of 22:6).
    So if I were to change the diff to 4.11, i would still need the sensor to turn 137 times per km travelled, the ratio needed would be close to 4.8 hence a 24:5 gearset would work.
    20:6....................
    Jealousy is a curse
  1. Question about Auto Transmission Strength comparison: A43DL vs A340E
    By SmokinSquirrel in forum Tech and Conversions
    Last Post: 31-08-2015, 08:18 PM
  2. W55 auto trans to w50 manual trans conversion
    By remo80s in forum Tech and Conversions
    Last Post: 11-09-2011, 07:57 AM
  3. Noisy front auto trans diff... oil?
    By MWP in forum Tech and Conversions
    Last Post: 05-08-2011, 12:37 PM
  4. wiring question auto trans
    By Azzamk2 in forum Tech and Conversions
    Last Post: 11-08-2009, 12:32 PM
  5. MX83 + 7MGTE auto trans question
    By Adash=P in forum Tech and Conversions
    Last Post: 27-04-2009, 11:07 AM
