http://masa-ya.jp/index.php?%BC%D6%2...E1%A1%BC%A5%BF
That's the page you're after, there's a pic towards the bottom with the 3 components you need to change on the tacho board
Hi all,
i know that this has been done years ago but cant find info on site (mostly links dont work)
History:
My Mx73 had the conversion done ~ 17 years ago with the non VVTi motor so is twin turbo, but tacho was never modded at the time
Car has been garaged for last 15 years and my son now wants to restore etc
can someone please supply details on mod works require and drawings etc for install
regards
Thank you very much,
remember seeing tis nyears ago
so if i read correctly just change out the two resistors and one capacitor to the values listed?
the feed to the tacho from one plug or ecu??
rgds
rob
Hi all,
having problems acquiring wiring diagram for a MX73 instrument cluster, need to identify the tacho input wire
i intend also to connect this to the tacho output wire from the 'orange' plug
Is this correct? have already changed the tacho board as listed above
regards
rob
Hi all,
having problems acquiring wirind diagram for a MX73 instrument cluster, need to identify the tacho input wire
regads
rob
