Results 1 to 2 of 2
Thread: Wheel Size Help!
    Jun 2016
    Default Wheel Size Help!
    Hey guys,
    I have an mx73 cressy, and found some wheels im really digging. However the wheels come in pairs of 15x7.5 and 15x9, i was wondering if these wheel sizes would be too much in width difference and have some cons to it. I will eventually lower it with BC Coils if that helps.
    Also should i run the x9 in the front or the x7.5 in the front
    Thanks
    Jan 2011
    Default Re: Wheel Size Help!
    I've heard (but not seen) wider front than rear on some awd vehicles. Some believe it will modify slip angles or make the rear breakaway more gently to reducing sudden oversteer. I've not seen it for RWD. I would think this is a conversation to be had with a steering/suspension expert. You plan to mess with the fundamentals of not engaging closely with fixed objects in a way that is a bit of an unknown.
    You need to check the wheel offset too. Not all wheels of those widths will fit/clear struts etc. Check some members rides for details but plenty of 9" wheels on old cressies.
    Also, you must practice your google-fu.
    http://forums.toymods.org.au/index.p...t=0#msg_368528
  1. Replies: 8
    Last Post: 13-01-2010, 11:04 PM
  2. ST162 Max Wheel Size
    By samet in forum Tech and Conversions
    Last Post: 27-06-2009, 04:47 PM
  3. wheel size confirmation
    By tyrannix in forum Tech and Conversions
    Last Post: 04-05-2007, 04:37 PM
