Results 1 to 4 of 4
Thread: MX83 Cressida - Manual - Built 7MGE - Coilovers - P Plate Legal
    Default MX83 Cressida - Manual - Built 7MGE - Coilovers - P Plate Legal
    1989 Series 1 Cressida for sale. Quick, well sorted car. Torquey, responsive N/A engine with 7700rpm redline and excellent handling plus the added confidence of upgraded 4 piston brakes. Not a hack job conversion, no engineers required and P Plate legal. Everything works as it should, this isn't an unfinished project.
    $4000
    Specs as follows: (I have probably missed a few things as the car was basically extensively built from the ground up a few years ago)
    BC Coilovers
    R33/BA front brakes
    Swaybars
    IS200 wheels with almost brand new tyres
    Nardi steering wheel
    JZX81 Cupholders
    W58 gearbox with nearly brand new heavy duty clutch
    One piece heavy duty tailshaft
    Genuine JZX81 clutch pedal and master cylinder
    Tricked up LSD (very tight, always spins both wheels)
    Built 7M-GE:
    Block decked, bored and honed
    11:1 compression
    40 thou oversize pistons
    ARP rod bolts
    High volume oil pump, upgraded outlet line, baffled sump, full flow cooler and remote mount filter (Z9)
    Billet aluminium oil cap
    Head decked, 3 angle valve job, heavy duty valve springs, extra coolant drain added to prevent BHG
    268 degree cams with adjustable cam gears
    Balanced and blueprinted
    AU Thermo fans, temperature switched with failsafe wiring
    Extractors
    2.5" mandrel bent stainless steel exhaust - sounds fantastic!!
    Technico billet engine mounts
    Car is currently running the stock ecu which has been modified to increase the rev limit to 7700 rpm however the engine is good for over 8000.
    I also have an aftermarket ecu and loom which will come with the car if it sells for the asking price (not installed).
    Brand new spark plugs and fuel pump fitted last week.
    I have a number of spares/upgrade parts that can be included in the sale for the right price.
    Car has a towbar fitted as i also have a cressida trailer (pictured) which was towed behind it, can also be included in the sale for the right price.
    No rego or roadworthy but eligible for historic rego.
    Located Ferntree Gully (eastern surburbs Melbourne)
    Never late in an x8
    Default Re: MX83 Cressida - Manual - Built 7MGE - Coilovers - P Plate Legal
    Deposit taken.
    Never late in an x8
    Jul 2017
    Did you end up selling it mate?
    Yep gone now thanks
    Still have a few parts left over if anyone interested
    Never late in an x8
  1. mx83 cressida 7mge manual conversion!!
    By 1jz-chriseda in forum Tech and Conversions
    Last Post: 04-04-2012, 01:23 PM
  2. bc coilovers- mx83 cressida
    By YGO 08 in forum Tech and Conversions
    Last Post: 26-08-2011, 05:20 PM
  3. Mx83 Cressida 7mge ecu pinouts
    By hosking1991 in forum Tech and Conversions
    Last Post: 20-07-2011, 09:24 AM
  4. Mx83 Cressida 7mge ecu pinouts
    Last Post: 18-07-2011, 08:28 PM
