Results 1 to 6 of 6
Thread: Question about wiring upgrade and power from battery
    Jan 2011
    Default Question about wiring upgrade and power from battery
    I finally got off my butt and got all the bits to do a H1/H4 upgrade to my ra23.
    The new wiring harness is obviously much thicker than the factory one and I know that I should be using the relays to pull power directly from the battery rather than the factory wires. Purpose being 1. to not overload old inadequate wiring and 2. Avoid significant voltage drop through the length of wire.
    Something I hadn't considered is that with the battery mounted in the boot, wiring to the battery would seem to be counterproductive. Is there somewhere else to pick up power from? I had thought alternator but I've read in some places that I'll end up with a voltage drop and lose some of the benefit of brighter lights.
    Advice much appreciated.
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default Re: Question about wiring upgrade and power from battery
    Starter motor solenoid.
    Jan 2011
    Thanks heaps B.
    and ground wire from the lights is just as important as the power wire
    the fat wire to starter motor/solenoid is permanent power..
    could also take power from the alternator output.
    for grounding, could ground straight to alternator body.
    Jan 2011
    Thanks guys.
    Lights went in today. Needed a sparky to make some changes to the wiring loom. Seems like the pinout was not quite right for neg switching anyhow. Miracle of miracles was that I made an online enquiry, expecting to book in tomorrow or later in the week. Next thing you know, guy calls me and says he's out doing a roadside breakdown and might as well come over if I'm free.
    Cost me very little for a home call and an hour of work, on a Sunday no less.
    I did all the physical install etc myself and I know the wiring is not going to burst into flame because I did it wrong.
    Just went for a night time spin and it's just entirely different. Stoked.
    May 2006
    Good to hear. I did the same upgrade on an RT104 I used to own and difference is amazing. I'll be doing the same on my RA28 when I get to that part of the build using BMW headlights
  1. Battery Relocation - Wiring
    By 81rolla in forum Tech and Conversions
    Last Post: 14-12-2007, 07:09 PM
  2. 4ag wiring issue, power to ecu but no power out??
    By SLO-055 in forum Tech and Conversions
    Last Post: 17-11-2007, 12:31 AM
  3. Something drawing power from my battery???
    By blacktop in forum Tech and Conversions
    Last Post: 26-10-2007, 11:11 AM
  4. electrical interferance between ECU wiring and battery cable
    By slide86 in forum Tech and Conversions
    Last Post: 10-06-2006, 02:02 AM
  5. calcium battery question
    Last Post: 11-01-2006, 04:04 PM
