Results 16 to 24 of 24
Thread: ANOTHA ONE - non-vvti 1JZ-gte out of a JZA70 breaks up under WOT ""HELP MEEE""
    Mar 2017
    WI
    Default Re: ANOTHA ONE - non-vvti 1JZ-gte out of a JZA70 breaks up under WOT ""HELP MEEE""
    Quote Originally Posted by Daddio View Post
    Sorry, I dont have any test procedure for the ignitor, other than swapping with a known good one. Pretty sure either a 1J or 2J (GTE) non vvti ignitor will be same although part number (89620-14460) is different...
    Thanks Daddio, I know I havent solved it yet, but Im glad to get a response from someone so I know Im not talking to an empty room. I did a few more tests last;
    -Checked for 12v across all the coilpacks to make sure they are getting the juice they need
    -Fix an oil leak(although this had nothing to do with the issue)
    -Looked at ECUmasters webpage with my cursor hovering over the PMU unit contemplating my future.
    I did notice though that as I blip the throttle, or just give it ANY throttle it almost dies before it revs. Is this an indication that the TPS is off?
    Jan 2010
    Quote Originally Posted by jdesign View Post
    Could be, but more likely a vac leak...I assumed you'd check for vac leaks first. (Oddly enough, I'm also currently 'shopping' for an ultrasonic vac leak sniffer...)
    Mar 2017
    WI
    I did a boost leak test, and it seemed to hold up to about 20lbs. After that some of the vacuum lines started to hiss. I have a manual boost controller on it at the moment which I have turned all the way down to 6psi so 20psi is a little excessive and I fell like I should be okay. Also would like to note that compression tested the motor and it came back perfect across the board and that all the gaskets on the motor have been replaced.(Intake, throttle body, V-covers, ETC)
    What do you need an ultrasonic leak detector for? A/C leak somewhere?
    Jan 2010
    Nope...I have a gas tester for tracing a/c leaks....I need an ultrasonic sniffer for tracing vacuum leaks in antique pianolas that I rebuild as a hobby (almost 200 leather valves, 100 cloth/leather bellows and several hundred feet of vacuum tubing...all under around 30-40" of water vacuum created by foot pedalled bellows)...24 valve 6 cylinders are a walk in the park in comparison
    Mar 2017
    WI
    JESUS. No thanks.
    Jan 2010
    JESUS. No thanks.
    There are 176 valves in this pic (88 you can see, plus another 88 you cant see, and around 20 more in other areas)...each has a clearance of 32 thousands of an inch, clearances set by gluing the wooden and leather components together. Each has to be vacuum/air tight, and must move freely (wooden shaft in a wooden hole) without side play...there are also over 100 bellows, each air tight and aligned, and obviously 88 keys (yes, real ivory and ebony) that are balanced to 0.1g and then levelled (with paper shims) to 0.01mm ...
    Mar 2017
    WI
    [QUOTE=Daddio;1617257]There are 176 valves in this pic (88 you can see, plus another 88 you cant see, and around 20 more in other areas)...each has a clearance of 32 thousands of an inch, clearances set by gluing the wooden and leather components together. Each has to be vacuum/air tight, and must move freely (wooden shaft in a wooden hole) without side play...there are also over 100 bellows, each air tight and aligned, and obviously 88 keys (yes, real ivory and ebony) that are balanced to 0.1g and then levelled (with paper shims) to 0.01mm ...
    That is super cool!! I know nothing about something like that, but it looks like the ultimate tinkering dream.
    I messed with my car a little more and moved the TPS around to see if the throttle "blip" issues would go away. It got better, but its still not running the way it should. Im having a friend look it over this week that has a few 1jz swapped cars with hopes that he can figure it out by swapping parts over from one of his cars.
    Jan 2010
    TPS is a possible culprit....CPS also.
    Mar 2017
    WI
    CPS is new, and I calibrated it according to this DIY:
    http://www.mk3supra.org/topic/56-gui...#comment-16225
    I have not touched the crank position sensor. I figured if it was bad, the car wouldn't even run.
  1. Running a VVTi motor with VVTi "off"
    By JustenGT8 in forum Tech and Conversions
    Last Post: 01-04-2014, 09:24 PM
  2. Replies: 8
    Last Post: 02-11-2013, 06:49 AM
  3. ST162 - "GTR" vs "SX" any differences?
    By XiL3D in forum Tech and Conversions
    Last Post: 07-07-2007, 12:03 AM
