The EV1 plugs fit and you can keep your original pre-crimped connectors.
its a tight fit through the new rubber grommet but it will push/pull through with a little teasing.
There were picked up from E bay (item 182376247462) and there are many around, I purchased from two supplier one set were pre-crimped the others as pictured (which I used) and there is little variation between the two types i purchased.
As mentioned the black item must be more UV stable as they have lasted.
There are 2 more plugs with offset keys for sensors which need replacing.
What i have found is the center keys EV1 plug are flexible and will bend over the keys and so can be used, they lock in place via the metal spring clip.
spoke with a few auto electricians who informed only the center keyed units are available , some if any one had seen the offset keyed items please advise.
M.
Just found these both left and right keyed
