Pin number 9 on the 16 pin diagnostic connector would be worth a look
Hi all,
Im trying to install an aftermarket tach to this vehicle but dont know where the tach signal wire goes?
99 Hilux 3RZ-FE
Can anyone help please?
Thanks
Jealousy is a curse
The OBD2 connector
Jealousy is a curse
mine is underneath the handbrake
Jealousy is a curse
Hi all, I'm still trying to install a tacho in my hilux but don't know where the tach signal wire is to connect to ?? Anybody help
Sent from my iPhone using Tapatalk
If you do not want to use the red/white wire to the obd socket take out the instrument cluster and connect to the red/white wire that goes to B9 on the cluster
Jealousy is a curse
Ok will try that, back out with the dash ! I thought the tach feed may be a plain black thin wire
