what is the current disc diameter? PCD, calipers?
No idea what the struts are.. they have 2 bolt bottom end compared to 3-bolt for KE1x
The LCA's have inner rod ends.. could be from anything
KE17 struts, with KE20 hubs which have same PCD as KE17, will fit KE10 to KE70 discs. KE30 to KE70 discs are same diameter and not much larger than original KE17 discs (i forget.. 200mm vs 218mm?) but will all bolt to KE20 hubs
I had KE15 struts, KE20 hubs, KE70 discs, backing plate and calipers (long thin pads, not the square ones). all bolt up
you could beef up and strengthen the chassis around the radius rod mount.. but it was never designed for that.
the chassis rails are double thickness up to the cross-member, but then single thickness in front of that (since no strength was needed there)
same with the top of the strut area not being so strong, as most of the load was originally taken by the leaf springs
i'd be temped to strengthen the front end, then put KE20 cross-member in there (or KE30 for a small increase in track)..
but original with original struts (cut down an inch for shorter KE20 shocks), with KE30-KE70 brakes, would be ok (and change master cylinder to something with dual circuit and booster.. or Galant GB? GD? for a dual circuit non-boosted MC)
