Results 1 to 6 of 6
Thread: 7MGE Water Pump Pulley Dimensions
    Junior Member Backyard Mechanic Bazooka's Avatar
    May 2006
    Default 7MGE Water Pump Pulley Dimensions
    Hoping this is an easy one for someone that has a spare 7MGE (7MGTE may be the same?) water pump pulley they can take some dimensions from?
    I need the diameter taken from the ribs the belt runs on, bolt hole diameter and PCD as well as center hole diameter. From what I can find it should be a 5 rib pulley, please confirm.
    Thanks
    Default Re: 7MGE Water Pump Pulley Dimensions
    Hi
    The rib OD is 112mm (5 rib belt)
    The center hole ID is 42mm
    The bolt holes are 8.5mm on a 62mm pcd
    Hope that helps
    Never late in an x8
    May 2006
    Perfect, exactly what I'm after.
    Sounds like it should work. Now anyone got one they wish to get rid of?
    Ive got a few here and could probably let one go if you're still looking
    May 2006
    Cheers mate but I have since acquired a pulley.
    Banned
    Aug 2017
    Wow, she is one of the most beautiful girls I have seen
    http://www.youtube.com/watch?v=xmxdAu6RQtM
  1. Replies: 7
    Last Post: 20-06-2011, 08:32 AM
  2. 7MGE air con idler pulley (Cressida - Supra)
    By petergoudie in forum Tech and Conversions
    Last Post: 05-03-2010, 10:23 PM
  3. Is 4ac water pump same as 4age rwd water pump?
    By s2k in forum Tech and Conversions
    Last Post: 25-10-2007, 10:55 PM
  4. 7mge Water Hoses
    By Flebbert in forum Tech and Conversions
    Last Post: 05-02-2007, 02:10 PM
  5. 4a water pump/pulley measurement
    Last Post: 21-12-2005, 05:19 PM
