Hi
The rib OD is 112mm (5 rib belt)
The center hole ID is 42mm
The bolt holes are 8.5mm on a 62mm pcd
Hope that helps
Hoping this is an easy one for someone that has a spare 7MGE (7MGTE may be the same?) water pump pulley they can take some dimensions from?
I need the diameter taken from the ribs the belt runs on, bolt hole diameter and PCD as well as center hole diameter. From what I can find it should be a 5 rib pulley, please confirm.
Hi
Hope that helps
Never late in an x8
Perfect, exactly what I'm after.
Sounds like it should work. Now anyone got one they wish to get rid of?
Ive got a few here and could probably let one go if you're still looking
Cheers mate but I have since acquired a pulley.
Wow, she is one of the most beautiful girls I have seen
http://www.youtube.com/watch?v=xmxdAu6RQtM
