The part number of the engine ECU you have listed is for JZS171
Have you wired up the MPX1 and MPX2 pins of the JZS171 engine ECU you are using?
If so perhaps the Toyota Multiplex data for the AC and external temperature is different on JZS171 vs GXE10 (IS200)... If that's the case it might be a tricky fix!
The signal to turn the AC on is sent to the engine ECU via the serial data Multiplex network I believe...
