Results 1 to 5 of 5
Thread: C56 Driveline Judder
    Jan 2007
    Default C56 Driveline Judder
    Hi. . .
    My car's developed a pronounced juddering on 1/2 - 3/4 - full? lock; AFAIK only when turning left. . .
    It's been building for a while; at first I thought it was just the tyre rubbing on the wheel-arch liner so didn't pay it much attention but it's recently gotten a fair bit worse (strangely enough only after I picked up a C160 which has been sitting in garage while I summon the motivation to actually put it in. . . ).
    At first I thought it was the LH drive shaft's CV joint but the symptoms are quite different; it's more of a bucking / jumping / juddering than the clicking normally assoc. with stuffed CVs. The importer I got the C160 off also doubted it was the shafts; he said that unless the boots have been torn (which they aren't) the shafts rarely fail.
    I then did a bit of Googling & apparently EG Honda's get this quite a bit & with those cars it's usually the LSD. If you're lucky a change of oil can save the day; if you're not. . $$$
    Was just about to swap in a spare LH drive-shaft but I think I probably need to pull my finger out & swap the box; or at least change the oil & see if it makes a difference.
    Has anyone with an AE92 / 101 / 111 with an LSD g/box had a similar issue?
    PS: What's the recommended lubricant for these ? The C56 was also bought off an importer; AFAIK its running the OEM helical LSD**
    **How can you tell what type of LSD's in a box?
    Jan 2007
    Default Re: C56 Driveline Judder
    It was the driveshaft. . . .
    Tallahassee, FL USofA
    What did it look like? Thanks.
    Jul 2016
    An intact boot is not an indication of healthy cv joint.
    Jan 2007
    As I found out. . .CV boot in question was undamaged.
  1. MA61 Driveline clunk
    By RyleyMA61 in forum Tech and Conversions
    Last Post: 04-06-2009, 04:45 PM
  2. Pinpointing a driveline vibration...
    Last Post: 25-02-2009, 05:59 PM
  3. Hilux driveline issue
    By Karbunkle in forum Tech and Conversions
    Last Post: 27-11-2006, 05:39 PM
