wilbo666 has lots of supra and aristo 2jzgte info
However that's more related to engine and trans than to some other stuff, but at least you may ask him
Ok so have a jza80 supra thats had an aristo 2jzgte put into it by someone
wondering where the aristos pps solenoid wiring would normally run through? does it run through the engine loom or the aristo body loom?
if it was in the aristo body loom im going to assume ill need to check for the PPS computer under the dash and see what wiring if any is available.
does anyone have a Pinout for the PPS computers plug
im going to assume it should be relatively simple and get the following information
speed sensor input
power
ground
pps solenoid +
pps solenoid -
Scott
SPARCO|TEIN|SUPERPRO|SELBYS SWAY BARS|PERFORMANCE PARTS AND APPAREL LIKE US ON FACEBOOK!
yeah have had a bit of a look over his stuff
and as you say its mostly engine stuff... will have another look over it in more depth though
so according to what ive found here
http://www.shoarmateam.nl/upload/MKI...20Diagrams.pdf
i was correct in my thinking
JZA80 PPS is on the engine loom. I'm pretty sure that JZS147 is on the body loom.
On JZA80 the two pins from the PPS ECU to the PPS solenoid on the rack are on pins 4 and 14 of plug 90980-11555 Engine Loom to Body Loom Plug (Orange).
SOL+ (Pin 4) goes to pin 1 of the PPS solenoid plug that is on the rack, SOL- (Pin 14) to pin 2.
All you need to do is wire up from the orange plug on the engine loom to the plug on the solenoid on the power steering rack (nothing else should have been done to effect the PPS ECU in the engine conversion if it was done properly...).
http://wilbo666.pbworks.com/w/page/4...0JZA80%20Supra
When u wire in an aristo engine into a supra u need to add the pps wire and afew others
I've done afew but people won't spend mooney to do it right
So others have done it but afew things don't work
Pps ecu has five wires
Ign
Gnd
Speed in
And the two solenoid wires
If your speedo works then pps ecu should be getting speed sig
So u should just have to run the two solenoid wires to the rack drivers side down low
yeah after seeing the diagram in the link I put in above i realised it would all still be in the car and connected up...
sure enough the pps ecu was there and plugged in so stole the pps plug and wires from an old loom plugged it in and soldered it back to the cut wires from the orange plug
worked fine...
