Results 1 to 5 of 5
Thread: 4age stopped firing
    Feb 2013
    ms
    Question 4age stopped firing
    After an upper end rebuild and timing belt change, MR2 4age was running fine, although not timed yet. Revved and idled well. After idling for 10 or 15 minutes, engine stopped and will not restart. Fuel is good. Havent checked spark yet. Wiring and vaccuum lines are fine. Not sure what would have fouled after running so well and stalling during idle. Any ideas would be very helpful.
    Chiba
    Default Re: 4age stopped firing
    Does it still turn over when you try to start it?
    Was the tensioner adjusted correctly after the belt was swapped (maybe it jumped a tooth)?
    Feb 2013
    ms
    Engine turns over fine, just no fire. Tensioner seems good, belt is tight and crank and cams match at TDC. Hard to think it would jump a tooth at idle. No fire at coil or plugs. Gas flow is good, but won't even pop with starter fluid.
    Chiba
    Pull a plug and see if there's spark.
    If not, check your leads and the wiring for the coil and ignitor all the way back to the ECU.
    Feb 2013
    ms
    Thanking you for your help. Not getting fire at either plugs nor coil. Checked wiring and found a loose ground and another connector beneath the intake and corrected. Checked all fuses. No frayed or broken wires. Suspecting coil, or computer glitch, but unsure how to test either. Double checked and fuel flow is good, timing and distributor are good. Anything further would be appreciated.
  1. 4AGE 20V Injectors not firing.
    By 70XIN in forum Tech and Conversions
    Last Post: 23-04-2011, 08:16 AM
  2. 4age firing order
    By KARNAGE in forum Tech and Conversions
    Last Post: 15-01-2008, 02:40 AM
  3. Engine Stopped while running! Help!! 22R
    By Herus in forum Tech and Conversions
    Last Post: 22-04-2007, 08:23 PM
  4. My 4age not firing up
    By Wanabe_Garage in forum Tech and Conversions
    Last Post: 23-06-2006, 11:19 PM
