Results 1 to 3 of 3
Thread: STOUT LITE Disk brake Conversion
    Feb 2012
    Default STOUT LITE Disk brake Conversion
    Hi
    Anyone know how or even if it possible to fit Discs to Stout LITES front?
    Any info would be much appreciated.
    Jun 2011
    queensland
    Default Re: STOUT LITE Disk brake Conversion
    as i understand it is the same process as fitting disc brakes to the RN10 and RN20 hilux, have a look how they do that.
    from what i understand using a donor 1979-83 hilux and tapping out M8 to M10 is part of the process (everything is the same just the hilux parts bigger/stronger), i have requested more photos and details on other forums as there are a few in the states that have done it.
    the "full" stouts share parts with cruisers and recently via the 60 series discovered that the hand brake on the 5 speed is via the rear wheels allowing a gearbox change, while in the process discovered that four wheel discs were possible with non genuine off the shelf parts.
    whats all this to do with a lite stout, well recently i noted again a comment about a lite stout with a hiace diff centre fitting the existing stout housing for better ratio, as finding the right axle spline was the issue and hence hiace. well i wonder if an early hiace/hilux hand brake is able to be used as a way around the hand brake on the gear box issue.
    with the "full" stout for discs the cruisers front rotors and calipers are used and it is only a mounting bracket needs to be made or brought to mount the calipers on to the bolt holes for the original drum brakes backing plate
    Low rep Grease Monkey
    Apr 2010
    bkk
    disk breaks rock
  1. Stout Lite re engine
    By Subscan in forum Tech and Conversions
    Last Post: 10-07-2012, 12:28 PM
  2. Stout lite Stud pattern
    Last Post: 21-04-2012, 03:48 PM
  3. Toyota Lite Scout Stout Diff
    By TA22 1MZ in forum Tech and Conversions
    Last Post: 11-05-2009, 06:58 AM
