Page 3 of 23 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 338
Thread: The Mega Supercharger 4AGZE thread, using twinscrew charger
    Default Re: Breaking a GZE piston or rod
    Stew would be loving this thread!
    California
    Here is 21psi slightly tuned. Had to cut it short due to ignition issues. Just shy of 200kw
    Ron
    South QLD
    what were the ignition issues ignition issues?
    California
    Quote Originally Posted by Cameron_Datto
    Not for sure, but I think it has to due with the wiring. Really need to make a new harness for the standalone.
    Ron
    now that this has turned into a twinscrew thread
    is there any reason why the SC manufacturers don't recommend the use of an electric clutch?
    given that the problem of overheating on cruise has been acknowledged... why not turn it off during cruise?
    California
    No reason for a clutch what so ever with the Twinscrew. The design is critical to the overall performance and life of the Twinscrew.
    Just for reference, I live very close to Kenne Bells shop
    Ron
    S.A
    Quote Originally Posted by RonRob
    Ron
    Top effort m8!!!
  8. #38
    CROSSPLANE CRANK! Domestic Engineer Merudo's Avatar
    I'm impressed!
    Certainly makes the SC12 look like the supercharger that can't! heh.
    I'm quite concerned now about what people have said about them overheating on cruise... especially since I don't know what has been done with my GZE in the rolla, as far as ABV mod is concerned, or other things.. Because I'm not entirely sure.
  9. #39
    Ron
    totally agree.. however... if it's not spinning... it can't overheat at cruise..... simple safety factor by removal
  10. #40
    California
    Thanks guys! This is the thread that encouraged me in regards to how robust the 4agze really is.
    I have never seen the Twinscrew overheat at cruise and do not know where these facts come from. I suppose an improper design could cause this or something similar. I have blown blowers on flawed designs, mainly due to a lack of support for properly setting up the Twinscrew. Just the countrary, I have very low outlet temps while cruising. I have recorded temps on the outlet at 265F during hot days at hard 21psi runs. 10 seconds after these runs the outlet temps drop 100F!
    Setup proplery these Screws Blow!
    Ron
  11. #41
    Damn... this thread certainly did take a turn to something else!! I'm going to have to spilt it apart now!!
  12. #42
    Genuine Hotty. Conversion King old_mr2's Avatar
    Default Re: The Mega Supercharger 4AGZE thread, using twinscrew charger
    I only just found this thread!!!!!! Awesome work ron!
  13. #43
    California
    Thanks and it has been sometime since I have posted but I can say with confidence that the kit will be available May/June. Here are some pics of the new design with Bigger Blower.
    This is our free flowing Inlet Manifold design that has the attatchment for the bypass valve.
  14. #44
    California
    A few more. Everything has been made out of aluminum with exception to the Bracket which is the only protoype left to make out of aluminum.
    This is the pic of the Outlet that connects to the 2 stage Bracket for ease of install.
    Here is the Upgraded Throttle body and Bypass valve.
    Notice how we are utilizing the stock Toyota 4agze Tps
  15. #45
    California
    Please note the bracket will be made of Billet Aluminum and the protoype is still being used for testing.
    Ron
