Looks like the same setup as the 18R carby. The spring tension should be enough to push the accelerator pump arm up. The pump arm might be tight at the pivot point or the plunger might be jammed in its bore if it has been sitting for a while. Can you move the pump arm up and down with your hand. It should be easy to move.
