Results 1 to 7 of 7
Thread: 7age 20v stroker?
    Jun 2011
    Default 7age 20v stroker?
    has anyone bothered? is it possible?
    2l or 2.2L any ideas?
    im just thinking of the low down torque
    Nov 2010
    tasmania
    Default Re: 7age 20v stroker?
    you really need to either include a lot more details of what you want, or do a bit more searching
    as it stands..
    yes, yes
    either, or
    heaps but not as much as beams
    Jun 2011
    Ah, so pointless, just wondering if its as easy as using a 3sge crank, forged rods and pistons with lots of compression
    Mar 2011
    Why not simply use a beams motor?
    Do you really want to have a 5 valve per cylinder head?
    SHEPPO..
    Quote Originally Posted by 13anshee View Post
    Ignoring everything else that would be an issue (crank main bearings, bore spacing etc) a 3SGE has essentially the same stroke as a 7AFE (86mm to 85.5) so you would barely be gaining capacity anyway.
    Jun 2011
    ah i see, cheers
    Junior Member Backyard Mechanic Dimitri's Avatar
    its been done. the road ratio is the issue. that and what has already been mentioned. $/performance youre better off with a 3s conversion.
  1. 2.2 litre 1G Stroker kits
    By 6BOOST in forum Tech and Conversions
    Last Post: 10-11-2018, 02:14 PM
  2. The HKS 2.4 1G stroker....... Isn't 2.4 :o/
    Last Post: 06-01-2008, 10:24 PM
  3. GT-Four ST185 3SGTE Stroker Upgrade
    By =dam0= in forum Tech and Conversions
    Last Post: 14-09-2007, 05:15 PM
