Results 1 to 15 of 18
Thread: 4AGZE piston rings?
    Aug 2009
    Default 4AGZE piston rings?
    Hi I'm currently stripping down an early AE92 GZE bigport engine & the plan is to do a franken-build using a 2nd gen GZE block with the oil squirters & higher 8.9:1 compression rods & ceramic coated pistons.
    I need to buy a new set of piston rings & am wondering if they're all created pretty much equal, or are there different types of piston rings for different applications?
    I'll be using a sc14 with overdriven pulley, 98 octane fuel & running synthetic oil once the engine has been worn in.
    Thanks.
    Default Re: 4AGZE piston rings?
    alot of people out there will say no, there are not created equal. most will say use only Japanese made rings, stay away from American made stuff.
    I too would like to know how they differ. i mean, its a cut piece of metal. Are the differances in the metal composition, Coatings, Tolerancing? I mean if they aren't perfectly round it usually won't matter will it? as they grind to suit your bores anyway?
    89' MR2 AW11... His
    00' MR2 ZZW30... Hers
    just run with GZE ones from Toyota. They are pretty good..
    Quote Originally Posted by wiso View Post
    composition = hardness and wear, and conformity to irregularities int he bore
    roundness = conformity to bore
    shape of edges = oil film differences and wear
    overall size/slot clearance/end clearance = leakiness or oil etc etc..
    lots of things....
    rings are not simple.
    edit: it also depends on the hardness of your bore too.
    Aug 2009
    Hmmmnn..???
    I'm seeing rings advertized on ebay but don't know if there's any difference between
    4age
    4age 20v
    4agze rings..
    rings used for boost, high revs applications etc.
    I could take it up with an engine builder that I know of before I re-assemble because I don't have any knowledge or experience with measuring cylinders or engine honing etc.
    Thing is, I don't know if they're reputable or not OR if they're familiar with the finer details of the GZE engine I'm building. I'm sure they know what they're doing.
    But if I could learn more before I go & see them that'd be helpful.
    Your mum is a Conversion King
    a
    If the Toyota part numbers are the same between 4AGE and 4AGZE of the same year, then the parts are identical.
    Jul 2007
    speaking of rings, has anyone got reports, good or bad, on NPR? from what i understand they are a jappo company that specialise in piston rings, mostly oem applications. theres a set of brand new 8.9:1 GZE slugs for sale pre assembled with NPR rings for a decent price is all.....
    1988 AW11 9A-GTE - project #1 | 1980 KP60 4K - project #2 | 1994 UZZ31 Soarer 1UZ-FZE - Cruise missile
    Apr 2008
    Nippon Piston Ring Co., probably make the OEM Toyota ones....concern would be if they were genuine (Jap made) or knock offs, like Chinese 'Nippon Racing'...
    toyota genuine rings are only around $250 when i last checked (several years ago tho) for GZE items, and i cant remember if they were different to 4AGE rings or not (i seem to think they are).
    I would just buy a decent brand myself, or genuine toyota.
    Aug 2009
    Ok guys, so the resounding answer I'm hearing most is 'toyota GZE rings' - can't go wrong I guess.
    & despite the cost, once they're in, 'they're in' ...so it's a piece of mind thing I'm paying for too...
    Thanks all.
    the toyota rings have also been deisgned and tested specifically for those pistons.
    do GZE's have a habit of breaking rings or ringlands?
    Jul 2007
    No. General cause of failure on any 4A seems to be oil system related. Usually spun bearings or failed rod bolts, the addition of boost doesnt normally change this. 4AGE+T conversions do seem to inevitably blow piston rings, but I think thats more of a mixture of using bodgy setups with old stock motors, which isnt all that surprising really.
    a
    As above, spun bearings and snapped rod bolts are the most common failure points on these things. I haven't heard of ring problems on anything but the crazy or bad builds (assuming they're bedded in right).
    There were two different thickness GZE rings when I ordered my new GZE slugs and rings from Castle Hill Toyota many moons ago. The rings they sent were for a different GZE apparently, so beware that there are two different thickness ring sets. I think it was compression ring #2 that was a different thickness to the ones they originally sent me, but dont quote me there as it was a while ago.
    Atleast, thats what Mr Sloan at CH Toyota told me anywho !
    But yeah, I vote for Toyota Genuine rings. Its what I am using......
    Jul 2007
    most likely the two rings are to suit the 8:1 pistons and 8.9:1 pistons....... just get the part numbers that corresponds to the same series gze and you will be right
  1. 4AGZE bigport and smallport piston rings - are they the same??
    By cam_ra40 in forum Tech and Conversions
    Last Post: 22-02-2011, 08:20 PM
  2. 2 type of 2t piston rings?
    By rotorat in forum Tech and Conversions
    Last Post: 09-09-2010, 08:06 PM
  3. Fried Piston Rings?
    By H1TMAN in forum Tech and Conversions
    Last Post: 05-11-2008, 06:39 PM
  4. 1G-GTE piston rings
    Last Post: 12-10-2007, 10:56 AM
