Results 1 to 15 of 23
Thread: 3SGE BEAMS 6speed bellhousing
    Jun 2010
    Red face 3SGE BEAMS 6speed bellhousing
    hey guys.just wondering if any of use no if a celica 5speed will bolt up to a 6speed beams bellhousing?
    Please let me no asap
    thanx
    Default Re: 3SGE BEAMS 6speed bellhousing
    no.
    the 6 speed has the BH integreated with the front of the gearbox.
    look at some pictures...
    Nov 2007
    Tasmania
    Quote Originally Posted by oldcorollas View Post
    no.
    Did you mean it's integrated, as in the bellhousing and gearbox are as one, like a k40/k50 gearbox from an old corolla?
    Looking at Altezza 6 speeds on ebay, it looks like the bellhousing is bolted to the front of the gearbox, so it could be removed? Though the bellhousing does look a little longer compared to a A or T series bellhousing, so it could contain some of the gearbox components.
    The bellhousing is cast as part of the front gearbox housing, so it is definately not able to be separated from the box by simply unbolting. If you are looking for a bellhousing to bolt to a 3SG, simply find one from a 2S-C engine (ST Corona, or a SA63 Celica), That way you can bolt a W55/57 or W58 to it.
    cheers Chuck.
    MS51Crown Coupe,
    If your bolting the box up to a 3S-GE (NA) then go for either a 2S Bellhousing, or a 3/4Y Bellhousing.
    If your bolting the box up to a 3S-GTE (Turbo) then go for a 3/4Y Bellhousing as it puts the starter motor on the inlet manifold side and away from the extra heat of the turbo. Also gives extra room for mounting the turbo.
    ([][][]II--LT--II[][][])
    if its for a 3sg(t)e why wouldnt you use the 6 speed???
    Past - 3 RA23's 1 TA22 - Hairdresser mobiles
    Present - Red 4age KE70 - Sideways shopping trolly
    Future - White KE70 - Grandma shopping trolly
    Quote Originally Posted by Munki View Post
    He has another thread going, where the same question has been asked, (3S-GE int RA65)
    cheers Chuck.
    MS51Crown Coupe,
    From most reports, not as strong as the W5x.
    im sure they will hold 200rwkw plus, but of course its all up to the driver. I guess if you are doing ipra racing 5 speed would be the choice.
    Nov 2007
    Tasmania
    The gear shifter position is further back on the 6 speed compared to the W5x, so that might be a factor. Unless there is a way of shifting it forward.
    Jun 2009
    act
    they is a guy on the altezza forums that has sucsessfully bolted a 3sgte into an altezza using the 6 speed with no major issues
    Quote Originally Posted by brucey View Post
    brucey, yep there is a way of shifting the selector forward, I have covered it in the other thread.
    cheers Chuck.
    MS51Crown Coupe,
    Quote Originally Posted by riderzx10r View Post
    6 speed and 3S engine were factory install for Altezza RS200 tho..
    Jun 2009
    act
    that is correct but the same gear box was used for the 1gfe as well I think
    Yes essentially the same gearbox, but the front section/bellhousing is then only suitable for the 1G series of engines, not the 3S's.
    Got a funny feeling that the "G" bellhousing bolts to a "T" engine, but the starter or clutch slave is on the wrong side. Way too many sleeps ago.
    cheers Chuck.
    MS51Crown Coupe,
  1. KE55 3SGE Beams Conversion
    By filthman in forum Tech and Conversions
    Last Post: 08-03-2012, 07:59 AM
  2. Replies: 8
    Last Post: 28-02-2011, 09:00 PM
  3. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 09:15 PM
  4. 3sge Beams & J160 q's
    By mattysshop in forum Tech and Conversions
    Last Post: 25-05-2010, 08:48 PM
  5. 3sge Beams in KE25 - Flywheel and Clutch
    Last Post: 15-08-2007, 10:43 PM
